AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic UT50 Series Discussion Thread
Official Panasonic UT50 Series Discussion Thread - Page 85
post #2521 of 2596
I hope you like it. It will definitely be better than the TV speakers.
post #2522 of 2596
+1
post #2523 of 2596
I got the UT50 early this year with a Sony BDP-S590. Both are connected using ethernet and connected to each other thru HDMI.
The other day when I decided to take an interest in streaming (setting out on a mission to watch Star Trek: TNG in HD), I ended up deciding to get Prime since they have S1 & 2 available to stream. What I ended up doing was testing between my Viera, my S590, and various streaming services after I couldn't help but feel the HD was really lacking when watching thru the Amazon Instant app on the Viera.
My ultimate conclusion was that there is actually a quality difference between the Viera Amazon Instant app, and the S590 Amazon Instant app. If you have Prime, you can check this out yourself, and I'd be interested to hear if others see the difference. Furthermore, I realized I really don't like Amazon's HD quality.
Vudu had the top HD quality with their HDX streaming. It looked as good as blu-ray to me. If I'm to rent from now on, it'll be on Vudu.
You can play the first 2 min. of a movie on Vudu, and comparing between apps and devices, it seems apps on the Viera always gave a slightly noisier, pixelated image quality. Also, between Vudu and Amazon Instant--regardless of device--not only were action, details, and dark scenes noisier on Amazon Instant, but there was a framerate performance difference.
If you have Prime, you can watch the beginning of Avengers, then watch the 2 min. preview on Vudu in HDX (requires fast connection). There's a lot of dark and detailed scenes. A scene where you glide over some dark glowing stairs, then following a helicopter over a cliff to a compound in the distance with many tiny cars and windows, followed by lots of movement of people. The stair scene in particular is where you can see the framerate difference. On Amazon Instant, the lights thru the stairs sort of lag and drag. On Vudu, you smoothly glide up the stairs. The difference is distinct. You can see the noise and pixels in plenty of these first scenes.
Another comparison is using Star Trek: TNG to compare Amazon Instant between the Viera and S590. The title sequence can be used. There's lots of details in all the windows, seams, and glowing engines, as well as the text, even. On my Viera, I can see pixels around the edges of the text, noise in the glowing engine, softness to all the details. It's like a high-quality SD. When streaming the exact same thing on the S590, everything is more crisp. There's still noise, but it's just the quality of Amazon's video, which after some investigating, I think I read on their site that you only get 720p unless you have a Tivo that allows you to download the videos to it.
This then gets frustrating when I've also seemed to stumble upon a streaming difference between the Amazon Instant apps in terms of connection speed. I get very spotty speeds on the S590. At first it was more often than not picking up a high speed and giving me the HD quality, but more and more, it will keep connecting between 1-2 Mbps(?). After getting fed up, I tried running the Vudu app to see if it was my ISP. Nope, it easily loaded up the HDX like usual. Then I switched to the Viera Amazon Instant app and it consistently tests my speed and gives me HD. When I return to the S590, I keep getting slow speeds. It seems there is a deficiency in the way the app handles initiating connections. It's even tedious in loading the menus compared to the overly-simple Viera app.
As for Hulu, it seems they stream at different rates depending on the program you select. I didn't pay that much attention to it because I really have no interest in spending money on it. I also didn't get a chance to test Netflix as I just recently cancelled with them.
post #2524 of 2596
I love amazon prime, but not always for streaming. I defer to Netflix first. Amazon isn't reliable for HD streaming. Vudu is top notch for streaming and very reliable, I haven't had one drop out with them. Netflix is what I would recommend for Star Trek, they have many series, I've slowly been watching the original series.
post #2525 of 2596
Your Sony player also has a watch list for Amazon. The Panasonic does not.
post #2526 of 2596
55UT50 is $599 at costco. I couldn't resist. 55 inch upstairs and a 60 inch downstairs smile.gif
post #2527 of 2596
Hey Guys,
I just bought the UT50 from costco. What a great deal and so far, I really like the TV.
I noticed on mine, there was the energy guide sticker on the front of the TV, just like the floor models have. Did anyone else's have this sticker? Or is it possible I got a floor model without knowing I did. I looked at a bunch of onboxing videos of panasonic TV's on youtube and none of them had the sticker. What do you guys think?
Thanks for your help,
John
post #2528 of 2596
Had that sticker on mine that came from Panasonic NIB
post #2529 of 2596
pretty sure mine had the sticker.
post #2530 of 2596
Thanks guys. This makes me feel better for sure.
I'll be writing in more about it later for sure.
post #2531 of 2596
Hi All,
I've had the 55UT50 for about 4 months now and overall I've had no problems with it. But yesterday I started having two problems at the same time.
I've got the set connected to my home theater system via HDMI through the HDMI2 connection (it has ARC) so I can get my netflix and other streaming audio through the home theater system.
But yesterday the ARC stopped working as well as the turning on/off the reciever.
I've checked the connection and vieria connect and other settings and all of them seem just fine.
Has anyone else encountered this?
What can I do to fix it?
post #2532 of 2596
Try turning off all the Viera connect settings. Turn off the tv. Turn tv back on, enable Viera settings, off & back on with the tv.
What AVR do you have, if that doesn't work?
post #2533 of 2596
Thanks for the suggestion. I tried that to no avail.
I have a Denon AVR -1912. I checked the settings there and did not see anything strange. What is weird, is that up until yesterday it was working just fine.
post #2534 of 2596
Sorry figured you'd tried that. I have a 3312, will check those settings.
post #2535 of 2596
Did you check your hdmi control settings on the Denon?
post #2536 of 2596
Yes and those were fine.
post #2537 of 2596
Swap out the Hdmi cable with a known good one?
Did you delete the tv source on the Denon by accident?
Think it may be a Denon issue?
post #2538 of 2596
HDMI cable is not the problem as I get a signal from the directv box and audio from that is fine. TV was never set as a source since it's connected to the output from the Denon on HDMI2. HDMI 2 is the port on The TV that has the ARC (audio return channel)
Nothing changed between 2 nights ago and yesterday. So I can't see any settings changing.
post #2539 of 2596
Unless you swap the hdmi cable with a known good one, you can't eliminate it as a problem.
Or, at least disconnect & reconnect both ends.
post #2540 of 2596
Did the disconnect to no change. I'm wondering how a cable can go bad overnight. Especially with no other symptoms.
post #2541 of 2596
HDmi is a less than perfect system, sometimes cables are finicky.
post #2542 of 2596
Post over at the Denon XX12 thread
post #2543 of 2596
HDMI is reliable. Its ARC thats finicky.
post #2544 of 2596
Originally Posted by CraigBobchin View Post
Hi All,
There is no real advantage to ARC over using an optical cable. Switch to an optical cable so you can spend your time on something worthwhile. Even if you luck into some fix this will probably happen again.
post #2545 of 2596
I have no idea how I would even set that up so the audio comes over the HT system when I have my normal audio coming over the HT theater?
post #2546 of 2596
I dont understand. Do you have an HT system and an HT theater? Whats the difference? What is "normal" audio?
post #2547 of 2596
The system is the same. a Panny UT5055 display Denon AVR1912 as the HT receiver/switch. My normal Audio would be the DirecTV DVR.
What was happening that I considered standard operations was I could watch Directv, then switch to netflix on the TV (without changing anything on the Denon) I'd get my sound through the Denon and could then switch back to TV.
Now I don't get the Audio through the receiver for Netflix, just through the panasonic.
Hope that helps clarify things.
post #2548 of 2596
Run a digital optical (toslink) cable out from the tv and into the Denon. Problem solved.
post #2549 of 2596
post #2550 of 2596
And much more reliable. I think my solution when I ran HDMI ARC was to turn the TV on first, is mattered what device turned on first. But an optical cable works every time.
