AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic UT50 Series Discussion Thread
Official Panasonic UT50 Series Discussion Thread - Page 86
post #2551 of 2596
Im trying to connect the HTPC on my UT50, but when i do through the VGA port, the max resolution achieved is 1366x768 and the 3D Function doesnt work, and when i use the HDMI i can set to 1080p, but the image cant cover the whole screen, theres black border in top and sides. i tryied to disable overscan, setting the aspect ratio to just but none of this worked
Another problem is that when i play a 3d video SBS from HTPC the 3d Function doesnt work as expected! it does not align the images right, causing a very strange feeling when using the glasses
Theres a way to use a HTPC on this TV?
post #2552 of 2596
Anyone able to get 5.1 audio from Netflix? Yesterday I tried to stream some HD content and 5.1 is available but the audio coming out of my receiver is only Stereo. When I press the info button on the remove, I see some number with ###SD. does that mean anything?
post #2553 of 2596
The ###SD means you are getting a standard definition picture.
Use an optical (toslink) cable from the tv to AVR and you will get 5.1.
post #2554 of 2596
Ok gotta try that. thanks.
post #2555 of 2596
I've had a lot of issues with vertical banding on my 9 month old set. Football and baseball games have bad vertical lines of discoloration in the green fields. Complex pictures are not much of a problem, but with any uniform colors, the set struggles. It's enough of an issue that I would have looked elsewhere if I had known I'd have this problem. Are there settings that would decrease this effect? Is this just an issue with the UT model line? Do I have a bad set?
post #2556 of 2596
Hello, I was wondering if someone can help me out with Game Mode Calibration settings? I've noticed a lot of Custom Calibration settings posted but not so much for Gaming. I've set my Custom Mode Calibration settings and I'm really loving the TV so far. Thanks for all the useful posts on here. I'm just not sure what to do with my PS3 in Game Mode. Any help would be greatly appreciated!
post #2557 of 2596
I think many people have posted that Game Mode is just like Custom except for the better lag time. I would use what people have recommended for Custom Mode and see if you like it.
post #2558 of 2596
Thank you very much for the quick response. I will try that!
post #2559 of 2596
Hello all.
I'm having an issue with my UT50 50": when I watch 4:3 DVDs I get black bars at the sides, as expected. I want to use the 4:3 setting in the TV to cover the side black bars with grey bars (IR prevention), but what I get is the grey bars then the black bars and finally the horizontally-squashed image.
DVD/BD player is a Panasonic 500.
Thanks in advance.
post #2560 of 2596
Check to make sure the BDP is set to its non-altering setting. Then set the UT50 to "Just" and you should only get the side bars in the shade you specified in the system settings.
Edit: "Full" is the setting you want.
Edited by anikun07 - 10/18/13 at 4:06pm
post #2561 of 2596
Thanks anikun07.
No luck doing that. Funny thing is that both settings for 16:9 TVs at the player provide the same behaviour.
post #2562 of 2596
Anyone notice that when entering the menu, when the menu takes up over half the screen that the brightness/contrast is higher???
Anyone figure out a way to make the TV that brightness/contrast when out of the menu?  I'd assume it'd be done through the service menu.  It's driving me absolutely nuts.
Btw I have a TC-P55UT50.  Thanks!!!
post #2563 of 2596
how do you guys clean the stand, dust sticks to it like magnet.
post #2564 of 2596
Swiffer. Or you can use a damp sponge with water and a microfiber cloth to dry with.
post #2565 of 2596
I will try that, but i was hoping a dry microfiber cloth is all that is needed, they should make those things like stainless steal next time. some material thats not sticky.
I got an unrelated question, do people use Overscan in settings? the broadcast channels have black border on their sides, i dont mind them from a visual perspective but do they harm the plasma due to image retention/burn-in? I also noticied sometyhing, that changing this setting for SD channels does not apply to 1080p channels and vice versa. And for blu-ray you would think the hdmi2 channel settings would be exactly same as when the dvd starts, but in fact the dvd movie has a different setting that needs to be adjusted on its own specifically the 24p smoothness which only shows up when the movie starts playing.
post #2566 of 2596
The black border isn't the projection on an image to the pixels are off. Sometimes there may be a pin stripe line along the edge of the back bar and the content and that could cause some IR, but I've never had issues. I watch a good amount of mixed content. I'd be more concerned about TV channel watermarks.
post #2567 of 2596
ive checked closely ive not found IR near there, but maybe in the center there is a vertical streak or a faint gap near the bottom thats lighter color than its surrounding, not sure where would that could come from. its hard to see, but could be IR. Its similar to 4:3 type image burn but it doesnt divide the whole screen, its just an inch or two of a straight faint line at the center or center right, with another one opposite it but even more faint and can hardly see. obviously seems like some graphic occupied that area but i cant think of anything since its at the bottom, maybe one of those news channels during some election who knows.
edit: would leaving it on playing movies on high contrast help?
Edited by dioxholster - 11/1/13 at 12:16am
post #2568 of 2596
It probably wouldn't hurt, but it should go away on its own over time.
post #2569 of 2596
does image retention stay even when TV is turned off? Because the "lighter" area is there when its turned off which leads me to think its a physical deformity of the panel not pixels being stubborn.
post #2570 of 2596
You can see IR for a little when the TV gets turned off, it's just the pixels cooling. CRTs used to do it, too. I can't remember if LCDs do it, but I don't think so. I've really only noticed this in the dark when all the lights are off.
post #2571 of 2596
I have a Panasonic P50UT50 that recently had some work done under warranty to fix a problem with the screen flashing snow/static and then losing the picture. It was fixed (kind of) but now it has a new problem of showing flickering white and black lines that run from a certain pixel to the right edge of the screen. It seems like it happens much more on bright colors like yellows, blues. I haven't seen any other issues like this on here and the TV guy I spoke with didn't know. I posted a video of it (sorry for the orientation), you only see white here but the black comes in eventually and has the same behavior. Also, the issue goes away when the screen dims for inactivity. Does this look like just a component connection problem, a ground issue or actual hardware failure? Based on the fact that it goes away upon dimming, I'm assuming hardware. Thanks for the help!
http://www.youtube.com/watch?v=rjoJ2gqiFwg
post #2572 of 2596
The SS board on my Panasonic died a couple of weeks ago (five months out of warranty). After I had it replaced, a weird "flash" of light started occurring during start-up. It happens right after the Viera logo appears. Sometimes the logo is still up after the flash washes out the screen.
I uploaded a quick video here: http://youtu.be/_dqZabNOFT8
Does anyone have any idea what could be causing this?
post #2573 of 2596
For those with the new Sony Mastered in 4k bluray,s.
The improvements with these disc,s is the higher bit rate and the first use of xvYcc ,extended - gamut colour space .(x.v.Color . Sony designation )
http://www.sony.net/SonyInfo/technol.../xvycc_01.html
With the use of xvYcc mastering and playback ,even products that support xvYcc may not work and some bluray players do not support it.Oppo 103/105 do not.
I have 2HT systems with 3 different bluray players.
The good news,Toshiba bdx3200ky enable HDMI deep colour 30bit,36bit , with Panasonic TH-P60UT50 plasma auto detects x.v colour.
Not so good,my panasonic Dmp-bd85 officially supports x.v colour.My samsung plasma series 5 2010 model according to samsung all tv,s after 2007 support x.v colour.With Samsung tv ,auto for colour x.v decoding will not work ,it must be manually selected.
It seems my model does not support x.v colour as the option should appear in menu when receiving x.v colour ,it isn't grayed out it doesn,t appear at all.
post #2574 of 2596
Just picked up the 55ut50 to replace a 50ut50 that they offered a refund on after the 8 blinks of death. Got it from costco for $599. Pretty screaming deal. It's also plugged into the surge protector, as opposed to the wall this time. Lol. Anyway, ice noticed that this new screen seems to be much better in its out of the box gamma calibration. The last one was a walmart, online purchase, and it looked great, but this one really seems to look noticeably better. Starting to wonder if it's just me,...Anyway, glad to be back with the Panasonic plasma, and here's hoping there's no more blinking.
post #2575 of 2596
Don't know if this has been posted but I found a New FIRMWARE yesterday.
post #2576 of 2596
Your link doesn't work.
post #2577 of 2596
Hi Gents,
I have had my 55UT50 since 2/13 when I bought it at Costco.
I have done some of the recommended calibrations and really like the picture quality.
Also had the hum issue fixed with the proper screws installed, and run my HT system with a very good Ultra Isolation Transformer.
Today I moved my modem and router closer to the set (since I'm waaaay to cheap to buy the dongle) and connected an Ethernet cable.
Has anyone done the firmware updates? Worth doing? Any issues with the updates?
Best,
Chris
post #2578 of 2596
Have done all the Updates without issue.
post #2579 of 2596
Last night I watched the original HOUSE OF WAX in 3D and was quite disappointed in all the ghosting on screen.
Does anyone know if anything can be done to improve the ghosting?
I'm wondering if different glasses could reduce the problem.
I haven't done any updating.
post #2580 of 2596
Watching in 48Hz mode can reduce ghosting, but for most people the flicker is horrible. Though if you shut off all light sources in your room, it reduces the effects slightly.
