Originally Posted by
QuiGonJosh
I'm kind of confused by one thing. If I set my BD player to 1080/24p, then that means the player is doing the pulldown, but if it's at 60hz, then the TV is doing it? Is that right or do I have it backwards? Which one is preferred?
Thanks for all the time and input Neo. You're...the one.
So I was watching a few BD's today and noticed that with 24p enabled, films had a slightly smooth look to them, almost as if the motion smoother was turned on, even though it wasn't. Switching back to 1080/60p looked "normal." Is this because I've gotten so used to the judder over the years that true 24p at home looks odd? When I have 24p enabled, turning 48hz on in the "24p Direct-In" menu produces quite a bit of flicker, so I keep it on 60hz.
Also, I've finally dialed in my settings. For me personally, much like I did with my PX80U, I've found that the custom settings are just too bright for a completely darkened room. I much prefer the look of the Cinema mode.
My settings:
Picture mode - Custom
Contrast - 77
Brightness - 52
Color - 47
Tint - +1
Sharpness - 25 (Not that there's any difference between 0 and 50)
Color Temp - Warm 2
Color Mgmt - Off
C.A.T.S. - Off
Video NR - Off
HDMI Settings
RGB Range - Auto
Content type - Off
Advanced
Block NR - Off
Mosquito NR - Off
Motion Smoother - Off
Black Level - Light
3:2 Pulldown - Auto
