Ok, STOP using those useless break-in slides/stills, its actually damage the pixels (plasma). It break-in the pixels in uneven way and possible causing uneven screen color IR etc. [Plasma Tv & Break-In Slides.. http://www.youtube.com/watch?v=XJjR1OjOlmgt
Pixel Jogger Breakin Improves PQ Plasma/LCD/LED TV...the only CORRECT way!
Warning: May cause seizure!
By simply displaying alternate Black and White screens in 30fps (= max NTSC screen 60Hz refresh rate), the PLASMA/LCD/LED pixels gets the CORRECT even/proper/intensive break-in/warm-up! All RGB Pixels will simply switches ON/OFF in 60Hz, this will jog/warm-up the pixels to switch faster and even.
Try it yourself, let the video play a few hours (see post #19) and see it yourself, you will notice it directly!
PictureQuality comes to Life in your face! Testproof it yourself now!. (and also see the real differences between properly break-in/warmed-up PLASMA/LCD/LED displays)
AMAZING overall (3D like) PictureQuality improvements in:
1) Higher Contrast/Deeper Black Level.
2) Higher Details Resolution.
3) Vibrant lifelike Colors (if your WhiteBalance is properly calibrated).
4) Faster/smoother movements etc..
Samples on youtube:
http://www.youtube.com/watch?v=_S-zDy9-_Lg
http://www.youtube.com/watch?v=uOfEwdDhjo0
http://www.youtube.com/watch?v=PvlF6NY2CIw
Pixel Jogger Breakin Improve your Plasma/LCD/LED TV...the only way!
Download mp4's:
a) Pixel Jogger.mp4 - 352 KB
http://www.mediafire.com/?hq5rv78qu1d9dhd
b) Pixel Jogger plus PinkNoise.mp4 - 2 MB
http://www.mediafire.com/?3i79g9u6rop4zd1
c) WhitescreenIR.mp4 - 1 MB
http://www.mediafire.com/?evee88qfnxarphi
Purpose: general pixel break-in/optimizer, IR washer/pixel resetter, image burnin/screen uniformity preventer/eraser etc.
Description:
a) Pixel Jogger.mp4 flashes alternate 0% Black/100% White screens to switch the RGB pixels on/off in max. NTSC 30fps (frames per second) display mode.
This will warmup/cooling each pixel in the display properly/intensively.
-main use: general pixel break-in/optimizer, possible fix/revive stuck/dead pixels and related issues. (experiment which is best)
-maintenance run weekly/monthy or at will to keep the display at optimal performance.
b) Same as a) plus audio pink noise for break-in the audio speakers/circuits for better soundquality.
Purpose: whitescreen IR washer/eraser plus pink noise audio optimizer.
c) WhitescreenIR.mp4 displays 100% solid white screen to erase any IR effects, run many hours, often check if IR is erased, else continue or Pixel Jogger.
Some users have good results after 60+ hrs to 75+ hrs running Whitescreen continuously.
Ok, share/spread your experience and results with us/others here/there etc.
Disclaimer: Do this at your Own Risk, I'm no responsible for any consequences! Except the PQ improvements!
Edited by iBrad - 11/27/12 at 3:21pm
Samples on youtube:
Download mp4's:
Description:
