Originally Posted by
PlasmaPZ80U
also, with dEUV the better the RGB percentages the lower the dE and all grayscale points are treated equally since the L portion of the formula is removed
By default CalMAN doesn't use L for dE76 or dE94 on grayscale readings, but at least the measured luminance level is used to determine the L*a*b* values.
The point of any dE formula is to report a consistent value that correlates to a visible difference. So a dE of 2 between to shades of blue is a similiar difference for two shades for yellow that are seperated by a dE of 2.
In that regard deUV is a total failure, it's values aren't consistent from either one shade to the next and is even worse when comparing targets at different luminance levels.
