AVS › AVS Forum › Audio › Receivers, Amps, and Processors › McIntosh pre amp questions
post #1 of 2
[SIZE="2"]Greetings all. I have a Mc Intosh C26 that I think is cauing distortion in one channel. Question, can I use my Mc6100 as a pre amp only by disconnecting the amp pre-amp jumpers with out causing a problem. My system uses a Mc225 for the horns and a Mc2100 for the base bins via a crown or raine crossover. If that will work can I use one channel of the amp on the 6100 and on of my other amps to try to isolate my source of noise?
Thanks for any replies.
Fred
[/size]
post #2 of 2
Yes. I think you mean MA 6100.
