Originally Posted by
jbelljbell
ok.... I'll bite.
Seams?
It does not appear so, and no mention is made of such. I haven't gone so far as to call them about it yet.
Doesn't HotSpot like a typical tarp? (aka you've used it, and have a few screenies to show?)
What part of "Toying with the idea of..." seems to indicate I've actually seen/used any of it?
Just messin' wit'cha.
But the material in question is made to Screen Print advertizing onto...it's the stuff that covers Billboard Frames. It's not glossy...as far as the description indicates, and that tends to indicate it's a Matte Vinyl coated material, as descibed.
The big picture
I think he means it could used as a surface for a painted screen, like, MS-MUDD or Silver Fire.
Is that right MS-Man ? would it work with those paints ?
Absolutely. And if one used it for a "Big Picture", big picture, say something like a 32' x 18' screen, I seriously doubt that any seam deemed acceptable for use on a surface that is viewed for advertizing messages would be too intrusive for use as a projection surface of such size, considering the distance one would sit/stand from such a surface.
No matter what, the available size vs. cost factor would/does outweigh many lessor concerns. And even if the surface is too glossy "raw", with the application of a "Gripper" primer" and any applicable paint, the end result would be worthy of being a screen surface that would cost many hundreds of not indeed thousands less than anything else one might...or could consider.
