I need to get a new reciever to get the most out of my klipsch VF-36 speakers and 12" klipsch sub.
They have excellent highs and great bass but when compared to my friends reference klipsch they completely fail on mids. After a few posts I have found out that some kind of EQ is my best bet, apparently the new EQ's listen to your speakers and adjust accordingly with the EQ.
Also my friend says it's because my old pro-logic amp is underpowered which it is.
What are some recievers you would suggest? I prefer Denon but would consider anything under $500
Current equipment
LG 42" tv (w/ optical digital out)
LG blu-ray (no optical digital out)
Klipsch Icon VF-36 towers
Klipsch 12" sub (very old and bass heavy)
xbox 360 slim
yamaha 5-disc CD player with optical digital out
no center but I want to go 5.1 (I have old box system yamaha speakers for rears to get me by)
Any features I should take into consideration?
Is optical digital out something I should take into consideration? Everything but my blu-ray has it and I can replace that down the road if needed. (TV xbox and CD player has it)
Current equipment
xbox 360 slim
