AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Optical Digital Out?
post #1 of 5
Alot of my components have Optical Digital Out and i'm wondering how important this is to take into consideration when purchasing a new AVR.
What are the benefits of using this?
post #2 of 5
It's a direct S/PDIF connection for digital audio. If that same source unit has HDMI, then it is not necessary to use S/PDIF.
post #3 of 5
awsome thanks
post #4 of 5
And, considering that pretty much all new AVRs have them, it's not like you have much choice about getting some anyway.
post #5 of 5
You'll want to use optical for your Yamaha cd changer. Your video sources all use HDMI so you should not need more than 2 optical inputs on your receiver.
