I haven't used my Z2 a ton, still working on the first bulb. Recently, I did my ritual of removing dust bunnies, I must have done this at last a dozen times now. I still have the original crappy filter in my Z2. Removed the screws, pulled the cover off. I took a can of compressed gas (Costco bought), for which I have a special tube attached, not the regular straight one. This special one is curved, so I can keep the can erect, and the end is sealed but has a couple of small holes punched on either side next to the end. The effect is to blow gas in opposite directions, does a decent job of getting the dust bunnies out if I'm thorough enough.
Well, I put the machine back to use and there's a noise... sometimes. A tap on the machine and the noise went away. It was as if a fan's blades were touching a surface and a tap caused some play to appear to stop the blades from hitting a surface. This syndrome continued next few times I used the machine. I took the cover off again (I needed to clear another couple dust bunnies too), and I had thought that maybe I had put the cover back wrong or something that would cause the fan to barely touch some surface. I could see nothing.
The problem continued, and I removed the cover again and inspected things. I thought I could see where the fan blade (it's on the left side as you look at the machine from in front, looking at the lens) was touching something. It's the smaller of the two fans, the one more toward the back. I can see it from the outside and it says on the label: DC PICO ACE 25. I'm guessing it's 60mm. I plugged the machine in, turned it on and off a few times. It looks not easy to disassemble things and replace that fan, but that may be what I have to do.
Yesterday I was using the Z2 and the noise started at the beginning, a tap or two and it went away IIRC. However, it came back and louder than usual an hour or two into using it. The room was pretty warm and this may have something to do with it. The room was around 83 F. Knocking the machine didn't stop it. The noise was very loud. I turned off the machine for a few minutes (it felt hot!!). Turned it back on and continued to use it even with the loud noise. I reasoned that maybe the fan bearing had worn out and shaking the machine or tipping it to move the fan blade forward or back would stop the impingement that caused the loud tapping, but jostling and tipping the machine had no effect. I use earbuds when using the Z2 and they block out most external sounds, so I kept using the machine and suddenly the sound disappeared and I continued until the recording ended, around another 45 minutes, no noise!
Hmm.
Two things:
1. Does anyone know what this is and can I fix it?
2. What's out there now in terms of getting a replacement PJ (I got my Z2 early on, Nov. 2003)? What's the best bang for the buck in a replacement (I know, that could be complicated)? Currently I don't have a 1080p source, just my DVD player and my 720p output MyHD 120 HDTV card. My biggest complaint with the Z2 is the horrible contrast. I'm pretty sure I could get something with far better contrast, new or used. My distance from lens to screen is around 10 feet. Suggestions appreciated!!!
Hmm.Two things:
