AVS › AVS Forum › HDTV › HDTV Technical › Picture but no sound using Comcast through an AVR
post #1 of 6
Hello....I'm a noob here. Not sure if this is posted in the right forum or not...please excuse me I am in the wrong area.
I have a technical problem. If anyone can point me in the right direction I wold be grateful.
I lost the audio signal with my TV. Video is fine. just no sound.
signal comes into the house via Comcast cable...from the comcast box into a Denon amp. Using all HDMI connectors. My Bluray player works fine, AppleTV works fine. When I switch to the TV speakers I get audio , just when I try to use the amp for the audio I get nothing.
It was working fine - I was changing channels and, boom, no audio.
equipment is:
Samsung D7000
Denon AVR1612
Samsung BD Player
Anyone??
post #2 of 6
Welcome.
If you go back and edit your thread's subject with your specific problem, you'll be more likely to get help. Just "technical help" will make most people just pass by your thread.
post #3 of 6
Title edited to make more specific.
Have you tried hooking everything up using component video and optical audio instead of hdmi? Or connect the Comcast box directly to the TV to rule out the Comcast box.
post #4 of 6
We need more specifics. How is comcast box connected to TV? How is comcast box connected to Denon amp? Do you have HDMI from comcast box to Denon?
post #5 of 6
If you did not link the comcast remote to do the volume control of the tv, make sure that someone has not hit mute button on the CC remote. Also, what box do you have from Comcast. They hand out about five different boxes depending on market.
post #6 of 6
If it is only the comcast that you do not get sound on try adjusting your programing selection on using the movie button on your remote or receiver, if this doesn't work go to your gui and see if you have set up your sound for cbl/sat to be hdmi or optical
  Back to Forum: HDTV Technical
