Originally Posted by
steve.black
Ok I found these two codes at Remote Central Forum. Again for a different model, but I am going to try them a well
New Discrete Codes for the HUMAX HDR-7500T PVR
Power On:
HUMAX KEY CODE: 0x7A
0000 006D 0022 0002 0155 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0717 0155 0055 0015 0E34
Power Off:
HUMAX KEY CODE: 0x7B
0000 006D 0022 0002 0155 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0717 0155 0055 0015 0E34
IR Scope resolved it to
Power On NEC1 0.16 OBC 122
Poer off NEC1 0.16 OBC 123
Now I have to see Look this up. Anyway I also need to try out earlier codes.
It look like RCRP05B cannot do NEC1 0.16 from the Lookup tool. Am I correct in this assumption?
I even tried CBL 0863, 1176, 1568, 1648 and 1670 (a lookup for Humax for Cable yielded these which match NEC1 0.16) and the remote rejected them all.
May be you are right in that this Humax STB may not have a discrete after all.
Anyway the learning was fun and that's what matters. Thanks for educating me, 3FG and mdavej.
I will keep trying.. Will try the Remote Master Software as well..
