AVS › AVS Forum › Audio › 2 Channel Audio › Onkyo TX-811 Speakers/Phono Help!
post #1 of 2
Not sure if this is the right forum, but here goes:
Just picked up an Onkyo TX-811 for the sole purpose of hooking up my Technics turntable and two Energy speakers. Pretty simple, you'd think...
I can only get one of the speakers (left) to work. The display panel on the front shows MONO, but I have no buttons to change that to STEREO.
Any suggestions?
Before I get flamed, I did search high and low but could find nothing, neither in these trusted forums, nor elsewhere. The only manual I found was the service manual which all read like Greek to me.
post #2 of 2
These two things are probably unrelated. Even mono should play in both speakers.
First, switch the two speakers. Does the same speaker not work? Then, switch the two turntable inputs. Does the same speaker not work? Also try switching the speaker cables. A little experimenting should tell you which part of the chain is the problem.
