AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The Merrimont trace Theater has begun
The Merrimont trace Theater has begun - Page 11
post #301 of 418
Originally Posted by snickers1 View Post
will be removing the drywall around the tub and replacing with concrete backer board
FIrst of all . . . happy birthday! Second - I bet your guests have never seen a properly built home theater before. I would imagine they were all very impressed. And last I would not mess around with this at all...put in the concrete board and rest easy that you don't have a mold buffet behind a polyethylene barrier. The reason I say this is that you have pipe / faucet penetrations through the membrane and there is risk of exposure through failed caulking at the juncture of the tub and wall. The wall board comes down over the lip of the tub, but there is not Kerdi that covers the exposed thickness of drywall. Considering the recommended gap between the bottom of the wall board and the top surface of the tub is about 1/8", one failure in the caulking which you might not even see and suddenly you are collecting water in the exact place you don't want water. AIN'T NOBODY GOT TIME FOR THAT!!!
Edited by TMcG - 2/5/13 at 6:07pm
post #302 of 418
it was nice to hear what people where saying but they really had no idea what they where looking at they just thought wow..
and if you dry to go into detail you see there eyes gloss over LOL!!!
thanks for the tip on what to do in the bathroom
post #303 of 418
Yup, sad but true. Most people haven't a clue.
Digital surround sound, subs, sound treatment and a big bright image...all my friends could say was "Hey, we should get together and watch some of our fishing tapes one day."
Ahhh, NO! For starters I don't have a VCR.
"What! All this stuff and you don't even have a VCR."
I need to get some new friends.
Your theater is looking great by the way. Always amazing to see the empty space take shape and turn into something special.
post #304 of 418
While I agree Kerdi over cbb is the best solution, kerdi over drywall is a proven method. I have seen many installs, done the research and made my own decision. As stated prior, the cbb on the plumbing wall is a good safety factor.
Beyond that, follow the instructions. 1/4" gap, completely filled with silicon prior to tile install. Install your tile and maintain them just like anything else in the home. If installed right the caulk between the tile and tub will last a decade or more.
Keep in mind cbb is porous, as is tile grout and it will transmit moisture into the wall. That's why when you remove it you can see the rust stains around the screws. You still have wood studs and the drywall on the other side as a breeding ground for mold.
Have I ever seen a serious mold problem (ie other than some black spotting on studs behind cbb.. no different than you might find in a garage or other damp location) with any system installed properly.. nope.
cbb.. drywall.. whichever.. kerdi is a waterproof solution over either substrate. cbb is not waterproof.
Tim
post #305 of 418
Just a FYI, Kerdi board from Schluter isn't the only game in town, I saw this at Conestoga Tille contractors show and tell and it looked just as good at a lower price point.
http://www.finpan.com/backer-board/propanel.php
post #306 of 418
Very cool Big.. always on the lookout for new and innovative products. Don't wanna drag this poor thread off topic, but that's pretty cool. For being so lightweight I wonder what the impact resistance is.
Tim
post #307 of 418
We had a carpet guy out to give us estimate
the color that really stood out was masland st marks square
the price i thought was pretty hight 725sq ft and 126 sq ft of black for the stage
4126.00
my friend gave the number of place that he used they supply the local big box stores
they only charge 15% above there coast for the carpet and then my friend hired someone else to lay the carpet so
i should have the price of just the carpet on monday and will see how much safes me going that route
post #308 of 418
post #309 of 418
my order of Duratex came this morning so it was time to finally paint the speaker the boxes that have been ready for paint for some time now.
u used a foam roller because i wanted a fairly smooth coat i never really like the heavy textured coat that you get when using a nap roller.
this stuff goes on very nicely it easy to work with... i ended up doing 3 coats... very happy with the product and highly recommend it.
cross overs are made to tomorrow i will finish up assembling and hopefully hook them up to a receiver and give them a quick test...
will post my thoughts and finally pics later.......
post #310 of 418
time for some sound!!.... well nothing makes your heart sink more then when you wire up your speakers and no sound!!! no where in the instructions did it mention the j3b jumper in right below the two white resisters but after looking at this pic i realized it need to be there mad.gif.....
once that was fixed we had sound!!!
Edited by snickers1 - 2/15/13 at 2:41pm
post #311 of 418
Attaboy snickers!!!!
post #312 of 418
What kind of cost and build time do you have in your speakers?
post #313 of 418
there is long standing thread on the econwave speakers at www.audiokarma.org ,
here is the parts breakdown all parts can be purchased at parts express
i did not use the cabinet kit i built my own boxes from MDF i am not sure how many sheets it took and i am guessing two.. but i used so much mdf in the theater i am sure i used a full sheet and some of what was left over from the theater.
as far as time .... i would i spent a full day building the boxes,
i think a spent a few hours in building the crossovers
then some bondo and sanding
i also used the duratex to paint the cabs..... i put 3 coats on each box which took a couple hours then over night to fully dry
then finally assembly was maybe three hours but i did run into a glitch but was easily fixed so that added some time.
so guess maybe 15 to 20 hours of work and costing around 5 to 600$ dollars. that compared to what i nice set L/C/R 's i think i saved allot...
not to mention when i tested these and heard how great they sounded the shear excitement of hearing something that i built with my own hands was priceless.
i am sure i would have been excited to hear a great set of speakers if i had bought a named branded speaker but building my own was exciting and fun.
post #314 of 418
ok so far the best price i was getting for the masland St. marks square are just to high ... i still have one person that is suppose to get back me with a price
here is the Masland sample
and this plan "B" Stainmaster silver lake ... which i can do for much cheaper
i really like the look and feel of the Masland it looked really good up against the grey in the theater area... but the cost difference is a killer confused.gif
what do you guys think??
Edited by snickers1 - 2/17/13 at 5:35am
post #315 of 418
I wish I could get carpet that cheap, the prices I was quoted on the Stanton carpet I chose were between $1,600 and $2,500 for just 198 sq. ft.
post #316 of 418
i am looking at 735 sq ft for $4,500 the rooms aren't that big but because of the pattern of the carpet and the two seems needed the guy says i will need that much frown.gif
post #317 of 418
I've just had sticker shock so far in my carpet buying experience I am going to have to look at cheaper options as well.
post #318 of 418
your room looks really good the masland would look great in there biggrin.gif $$$$$$
post #319 of 418
Yeah, the masland does look better. Great job on the speakers btw.
post #320 of 418
Thank you .... i know i like the Masland better also ..... i may just have to wait a little longer and save my pennies
post #321 of 418
I prefer the Masland and based on the pricing you are getting, I think it's a pretty good deal. The carpet store I went with gave me builder pricing and said the square foot cost I was getting would be the same even if I was doing the entire house. My 2nd quote was within $50 of this one.
For comparison, my cost breakdown looked like this:
Floor & Riser
309 SF Masland Quadrate-Times Square w/ 3/8" pad (floor & riser) @ $5.15/sf=$1591.35
Labor + extra charges for riser, riser steps & pattern match=$149.65
Stage
81 SF Masland Signet- Black w/ .45" pad @ $5.75/sf=$465.75
Labor + extra charges for stage steps=$96.25
Misc.
.45" pad + labor to relay existing carpet in new media closet (30 sf)=$100.00
Total=$2403.00
It's a big expense either way. I'd say go with the one that you like best.
post #322 of 418
Floor & Riser
Stage
Misc.
Total=$2403.00
thanks ..he was not charging any extra for the stage and riser
actually here is how he breaks it down
The first cut of carpet I need is running parallel to the length of the stage in the theater area. It will be 12' x 16' (192 square feet). The next cut of carpet will run from the wall behind the stairs all the way to the back wall behind the bar (before the bar begins). It needs to be 12' x 21'6" (258 square feet). The third cut will run from the doorway to the "game room" to the beginning of the bar. That cuts needs to be 12' x 15' (180 square feet). Finally, the final cut I need of the Quadrate will cover the raised platform in the theater area. Because I am running the carpet east-west, that cut needs to be 12'x 8'9" (105 square feet) to cover the platform and the drop down to the main floor. The remaining part of that piece is being used to cover the steps. The total needed of the Quadrate style is 735 square feet.
For the stage, I have to make sure the carpet I use covers from the far back wall all the way to the furthest south tip of the curves step. Because the stage is 15'7" at its widest point, to cover this without seams I would need a full 12'x15'9" piece of carpet (189 square feet) if I ran it east-west. However, as I mentioned when we met, I was willing to run the carpet north-south and put a seam on the stage in order to minimize the footage needed. To cover from the back of the stage down the front of the stage nosing, I need a 5' length of carpet. I need two of these 5' lengths to cover the stage and the step, so I am ordering a 12'x10'3" (126 square feet) cut.
There is obviously going to be some leftover small pieces of waste carpet, but that is a normal part of any carpet installation. By the nature of the beast, you have more waste associated with patterned carpets. I also explored the option of running the carpet in the north-south direction and no square footage would be saved.
The normal pricing for the Masland Quadrate is $5.52 per square foot, fully installed with padding. The normal price for the solid Mohawk carpet on the stage is $3.29 per square foot, fully installed. Your proposal is based on ($5.52 x 735) + ($3.29 x 126) = $4,471.74. The proposal then reflects the 10% home show discount included.
post #323 of 418
rear speakers came in today
Klipsch RS-41 II Reference Series Surround Speaker
i choose these because i very limited in space for the rear due the fact it is a open concept theater
in this pic you can i only have about 10" inches of space up near the ceiling, the grill that comes with the speakers will blend in real nice.
post #324 of 418
second carpet quote today... ok this guy came to me highly recommended from a long time friend that has used him several times and has raved about him ...
the first price i got for the masland was almost 4500 and this one came in at 3300 so this will be the one i go with in the beginning of april.
i did ask if service Maryland and he does so if anyone in the northern Va and Maryland area would like his number please just send me a pm and will be happy to share.
very very nice guy.. he not only beat the price but was very down to earth and explained exactly how and why he would do this and that.
Edited by snickers1 - 2/22/13 at 7:09am
post #325 of 418
Too late! I paid for mine Wednesday. Glad you found a good price I'm sure it will look great.
post #326 of 418
very nice can't wait to see the pics i'm jealous your geting your done before me tongue.gif
post #327 of 418
We just put carpet in our HT for $575 out the door. The room is 12' x 16' with a riser, but no stage. We were willing to take what they had in stock at a local discount carpet store and love it. It is a well installed thick multi colored carpet with pad. It is pretty dark with lots of greys in it. This is a much lower scale (and price) HT, but you can find deals...
post #328 of 418
Great work & thanks for sharing. This thread is an awesome resource!
post #329 of 418
Wow great work and great finished product! I've read through your build and Big's simple false wall thread and have a couple questions on the GOM color and the use of MDF
You mention you have Baltic Blue on top and Big mentions Crystal Blue on top with Baltic Blue on bottom: do you mean on the same panel you have used the two GOM colors two-tone-like or what? Also are the GOM panels on sidewalls just for looks or do they serve an acoustic purpose?
I'm unclear as to the use of the MDF board as paneling below the chair rail, why not just put the shadow box molding on the dry wall itself? I'm assuming the paneling has a better look but in what way? Also does the MDF cause greater acoustic reflection?
Thanks in advance
post #330 of 418
Thanks in advance
In Bigs build he used gom above and below the chair rail... in my case i went with the gom (baltic blue) above the chair rail. in my case i used 3/4 mdf below the fabric panels because the fabric panels are made from 1x2's . the reason is thickness of the mdf and the chair rail would match the thickness of the panel with the fabric wrapped on it. It creates a nice flush finished look . i also used 1x2's above the fabric panels and then installed the crown molding again this ment the fabric panel would end up flush to the bottom of the crown and also to the chair rail.
as far acoustic that i am not sure of it was purely done for looks smile.gif ... and can tell you that the mdf was attached to wall with screws and green glue and behind that is two layers of 5/8 drywall and green clue.
