OK, I confused Intel with AMD. DP with a DP-HDMI adapter supports the following audio formats:
AMD Radeon graphics since HD 5xxx
- With a passive adapter: Multichannel LPCM, DD, DTS, DD+, TrueHD, DTS-HD (i.e. DP = HDMI exactly)
- With an active adapter: Multichannel LPCM, DD, DTS, DD+
Intel HD Graphics (SNB, IVB) (I checked with Celeron G530+ASRock Z68 Pro3-M)
- With a passive adapter: No video / audio (i.e. Intel DP does not support dual-mode)
Supported audio formats over DP vary with the mb, as seen in DH77EB manual. BTW
- Passive adapter means DP sends HDMI signals and the adapter converts HDMI by simple pin arrangement (hence such an adapter is cheap).
- Active adapter converts DP signals to HDMI signals by a chip in the adapter (hence expensive)
On the other hand, DVI with DVI-HDMI adapter of ASRock Z68 Pro3-M is identical with HDMI in every respect. Again this may vary with the mb. But I am pretty sure DVI with DVI-HDMI adapter of every ASRock mb is identical with HDMI.
Edited by renethx - 3/29/13 at 10:12am
