DSCF1234.JPG 3209k .JPG file
DSCF1252.JPG 3155k .JPG file
DSCF1254.JPG 3215k .JPG file
DSCF1285.JPG 3421k .JPG file
DSCF1291.JPG 3158k .JPG file
DSCF1295.JPG 3150k .JPG file
DSCF1298.JPG 3202k .JPG file
Can't believe it took me this long just to post pictures. If you noticed the noctua fans are installed for positive preasure, but they cool much better flipped around, exhaust, which is my curent setup. If you want to install an optical drive, you'll need a cpu cooler 40mm high or less, this will also give you clearance to hang a 2.5 HDD off the bottom of the optical bay. I'm running an older ECS H55H-I motherboard, I3-550, 4GB's memory, and a PNY GT430. Case gets a little warm, but I'm also running the fans at their lowest settings, 800 RPM I believe using the Low noise filters that came with the fans. right now, the CPU fan is just audiable over the hard drive, the noctua fans, completely silent.
Notice, the picture of the case, you see a dimm glowing blue light, the PC is a sleep, but that light, on the internal power board, is on 24X7 if the PC is on or not, the power on light is not to bright, and the HDD activity light seems to have a dimmer, meaning that the live TV buffer is just enough for a very faint red flashing more of a glow than a flash, not too distracting when watching TV, but durning boot, windows updates, and other HDD intensive uses, the HDD activity light is very red, but again, not to bright.
So far I love the case, I finally can fit a decent powered PC in my entertainment center, I've taken the doors off the cabinet until I get around to adding an exhaust fan to the rear of the cabinet, i'm going to power the fan with the rear molex connector on the case.
Edited by dbailey75 - 11/30/12 at 5:32pm
