I am looking to slowly build a 5.1 system, piece by piece. I recently blew a lot of money on a projector, so I am going to have to cool off my spending a bit. I am thinking I can spend about $200 a month until I get my 5.1 system completed. Here is my problem... I know nothing about setting up an audio system. I did a little research, and here is my plan for spending about $200 a month to get a good system. I am not sure if everything is completely compatible, so I would love some input about my choices.
I will likely only have my Xbox 360 and my WD TV Live hooked up to the receiver.
Month 1 - Yamaha Receiver
. This is what I am most worried about. The receiver is a moderately complex item, and I know nothing about them. No idea if this is the best option for me at the $200 mark, but it is getting decent reviews.
Month 2 - Sony SS-F6000
(fronts). I will see how happy I am at this point. I may just stick with this two channel setup for awhile if the audio is satisfactory...
Month 3 - Sony SS-B3000 (rears), Sony SS-CN5000
(center).
Month 4 - Sony SA-W3000
(subwoofer).
Throw in some decent speaker wire
, do a little research to make sure I don't screw anything up, and I have a decent audio system. Any thoughts on my plan/ setup? I am just worried that I am missing something in my plan, or am making some big mistake.
so hang on to your wallet !
