AVS › AVS Forum › Video Components › Home Theater Computers › Is this possible with HTPC?
post #1 of 12
Hi everyone. I am thinking to build my first HTPC (never built a pc before) for my dedicated theater room. However, the more I read I get discouraged (due to lack of knowledge in this area) and quite frankly, I do not even know if I need one. here is what I am looking for HTPC to do;
1) I want to use it as my main blu-ray player to play AND copy content on the HD for future viewing. Needless to say I want to maintain the original PQ and SQ.
2) surf the net using benq w6000 projector on 135" screen.
3) view pictures and home videos.
In the room I have Fios cable box which can stay or if not too much hassle I would like to use HTPC (and save cable box rental?)
I use netflix, hulu + and youtube but I can get Ruku or something else and my receiver (pioneer vsx-1121k) has Pandora and internet radio.
am I inventing a new bicycle or I can benefit from building HTPC since I am not looking to use all/many of its abilities?
post #2 of 12
That all seems pretty simple and do-able.
Welcome to HTPC
post #3 of 12
Yes. HTPC can do all of the above.
post #4 of 12
Great, thanks guys. Any budget minded advice on core components?
post #5 of 12
I have posted this a lot recently if you want to search I had a thread called cheapest ever decent htcp.
Many options in there...
In a nut shell,
AsRock 1155 mobo + sandy CPU+ cheap SSD is good foundation
You can also click the link in Assassin signature above because he has an excellent guide posted as a sticky in this forum. He covers everything you need to know.
I would recommend purchasing his paid guide. It's excellent. Will answer all your questions and a bunch more you don't even know you have yet.
post #6 of 12
For the FiOS / cableCARD, go with an HDHomeRun Prime. Everything else is pretty standard for HTPC requirements. The more complicated part will be software.
post #7 of 12
For the HTPC, $300 is probably as cheap as you can easily/reasonably expect to go unless you have components laying around. Read the stickied threads at the top of the forum. That does not include a cable card tuner (Ceton or HDHomerun Prime) and only a small hard drive that will fill up after you rip some movies or record some television. If this will be a HTPC with internal storage, a budget of $500 will get you everything plus a few upgrades like a better keyboard/mouse/remote.
post #8 of 12
Hey my requirements are quite similar to yours. Except I don't need BlueRay but replace a DVD drive with BlueRay for extra money and I am cutting cable. If you want cable go with HDHomeRun Prime or Ceton recommendation.
My thread - http://www.avsforum.com/avs-vb/showthread.php?t=1406726
Budget ~600
post #9 of 12
hardware won't be bad for you, wanting to rip blueRays in a raw format, now thats going to cost you an arm and a leg getting a good NAS/SAN array large enough to store that...
but yes, htpc can do all things ever!
post #10 of 12
In a nut shell,
http://www.newegg.com/Special/ShellS...5-_-04242012_1
$258 delivered
Combined Total: $354.94
Combo Discounts: -$96.45
Combo Price: $258.49
1x Broadway Com Corp 1244MA-BLACK Glossy black Steel ATX Mini Tower Computer Case 500W Power Supply (Model:1244MA-BLACK)
$39.99
1x GIGABYTE GA-H61MA-D3V LGA 1155 Intel H61 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard (Model:GA-H61MA-D3V)
$69.99
1x Intel Pentium G620 Sandy Bridge 2.6GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics BX80623G620 (Model:BX80623G620)
$69.99
1x G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBNT (Model:F3-10600CL9D-4GBNT)
$24.99
1x SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive (Model:HD103SJ)
$109.99
1x TREND MICRO Titanium Antivirus 2012 - 1 User for System Builder (Model:TiTAV19497)
$39.99
post #11 of 12
http://www.avsforum.com/avs-vb/showthread.php?t=1404685
This thread has many builds under $300 and a good example of budget HTPC builds
post #12 of 12
thanks everyone. Glad to be in this HTPC community getting excited to start my build but I definitely need to do more reading. I also have some parts at work that might be perfectly usable for my build so need to check that as well (i know i have i5 processor from dell tower computer that is not being used as well as 4 gb ram). I like the idea of building a budget oriented htpc first because I am sure I will want to build a better one next (sort of learning from mistakes) and around $300 builds are very encouraging.
