I just purchased this woofer from a forum member.
I want to build a ported box comparable in solidity and performance to the 13 Ultra if possible, while not necessarily using the same dimensions.
I have a never used EP4000 on standby.
My dilemma is this. I found out after purchase (unfortunately) that SVS doesn't publish their T/S parameters so I don't know how I'm going to get a proper sized box built without this info. The seller said that SVS told him that for a PB13 Ultra to be effective it needs an internal volume of 5.5ft^3. I don't know if this was given to him as a guideline for the box he was planning on building for the extra PB13 woofer or if that is the actual internal volume of the Ultra box, or both.
All help is appreciated.
