I am finding different pricing on a replacement bulb from $400 to $99.
is it true that there are certain bulb manufactures (Phillips or Osram) you need to look for to get your moneys worth?
The bulb that came with my projector is at 1980 hours and still going strong and showing no signs of dimming. At start up on the projector it tells me to replace the lamp. Can i still use this for a few more hours?
Thanks for any advice
