I'm moving into a new house. It's setup so that the TV is in the front of the living room and the units are in the back of the room. It requires about a 50 foot run through the walls/ceilings, which I don't have access to. It was built in 2004, and the wiring was put in before the drywall was added. It currently has the following cables wired:
DVI
VGA
2 Coax
1 Cat 5 cable
I'd prefer to wire a redmere HDMI cable, but I can't figure out how to do so, and the cables won't move/slide at all for feeding purposes.
What are my options if I want 3D and other high end HDMI requirements?
HDMI over Cat 5? It's only cat 5, will it be stable enough?
EDIT: It is actually cat5e, whether it's the same cable poking through on both ends is another story.
HDMI over coax? Will this cover the requirements?
DVI
VGA
2 Coax
1 Cat 5 cable
