AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Rear surrounds placement
post #1 of 13
I need help figuring out the best wall to mount my right rear surround on. The speakers are Paradigm ADP-170 dipole's. The squared off portion of the room is about 14' x 14'. The back of the room opens into the dining room and kitchen. Opening is about 8' wide.
If I mount the speaker in location #1, it will be directly inline with the ears of those sitting on the love seat. Location #2 will put the speakers behind the listening area.
Attached are two photos. The first picture shows the right wall (when facing TV). Should I mount the speaker in location #1 or #2?
post #2 of 13
Probably location 2...... And I'm assuming you really don't mean rear surrounds, just surrounds right? Rear surrounds are only found in 7.1 or higher.
post #3 of 13
Yes, just surrounds in a 5.1 system.
I've attached a crude drawing of the room. This should give a better idea of what I'm trying to do.
Should I mount the rears in position #1 or position #2?
post #4 of 13
Ok... That drawing totally changed my opinion.... Position 1 gets my vote.
post #5 of 13
Another vote for position #1, since those locations will keep the left and right surround speakers at roughly the same angle to the main listening position.
post #6 of 13
Thanks, guys!
post #7 of 13
#1
I was confused by the two initial pictures, and didn't realize there were two different locations in each.
post #8 of 13
Perhaps the speakers are too high on the wall? Or are they angled down some?
post #9 of 13
They are way too high! Way way too high M
post #10 of 13
Why? Just what is the height you determined from the pix?
post #11 of 13
perhaps from the pictures in the OP first post - though they do say subsequently at ear heigh :-)
post #12 of 13
Position #1, but 2-3 feet above ear level, as Dolby recommends. Tilt them down to ear level so that tweeter frequencies aren't lost.
post #13 of 13
Position one without question. You always want the nulls facing you. This is the front of the speaker that usually has no driver or a non-directional low frequency driver.
