AVS › AVS Forum › Other Areas of Interest › What's Your System Configuration › Carp's basement hide-out
Carp's basement hide-out - Page 8
post #211 of 243
thanks Dom
that video is insane!! I didn't even know that was possible! That said, I do have cracks in my wall where I cut into it to repair the damage to the vapor seal when I was running speaker wire to my right side surround. There goes my careful drywall repair work.
post #212 of 243
The SMS-1 was set to no eq for this. Also, I think I'm done with the sms-1. When we took it out of the chain we were getting 8 more db's than before on the same settings (we level matched the subs/speakers again after removing the sms-1). It neutered the crap out of the subs.
Unity gain on the SMS-1 is 16 in regards to the volume control so it should just be a pass through. I have never noticed a difference with it in and out of the path but I always have the volume set to 16.
post #213 of 243
Killer set-up by the way Carp!
post #214 of 243
Thanks mjaudio!
I finally covered my white outlets - with bass traps! I wasn't using them so I figured this would be the laziest way possible to take care of it.
Here is a shot with a folding chair to show the scale of the speakers/screen
post #215 of 243
where's the bleach spot?
post #216 of 243
boom
Haha, what an idiot.
Man, that sucks but everytime I see it I'm reminded of how fun/crazy that night was and it doesn't bother me. My house has never experienced such crazy volumes before or since!! biggrin.gif
post #217 of 243
Thanks mjaudio!
^^^ This is so sick.
Your front stage is so damn intimidating! Great clean look. I love it! Congrats!
post #218 of 243
That just looks scary....and awesome at the same time
post #219 of 243
Thanks Kevin!
Well, I finally got sick of being able to see the black bars in bright scenes above the screen so I found some left over black velvet from what I had my "screen" frame wrapped with.
SOOOOOOO much better. I can't see the black bars at all in dark scenes now above the screen, 100 percent gone. I should have done this a long time ago.
Here is a pic with the masking panels in, this is how it usually is since I mostly watch tv.
post #220 of 243
At first my plan was to tack the velvet along the front wall up to the ceiling (90 degree angle) and then along the ceiling back towards me. I quickly realized it would be much easier to just go diagonal from the top of the screen border to the ceiling, and this way I got more coverage on the ceiling - 2 feet from the wall. I just wanted to see how it looked and figured it would look bad and wouldn't work out, but it actually looks very good. The beam is another issue, I don't know how to make it look good but I have to cover it or it is even more obvious now that above the screen is taken care of.
post #221 of 243
Wow, that is one hell of a room you've got there. Clean and simple, very nicely done. Can't wait until I'm no longer renting and can have a dedicated space like this.
post #222 of 243
All that room needs is some nice white electrical outlets to offset the black and add some color. wink.gif
post #223 of 243
Carp - the velvet looks great! Did it seem to help with the contrast/picture too?
post #224 of 243
How are you sticking the masking to the screen? One of the pics makes it look like you have a 1.85 masking?
post #225 of 243
Thanks! Yep, I remember well the days of renting - for me it was always apartments. That was brutal not being able to crank it up.
Ha, well now that I have that taken care of I get suggestions that I get a dark rug and paint the ceiling. The video quality nazis are all over me!! They are right of course, but I don't want a bat cave.
It helps for sure with 2:35:1 movies - so much better. I don't think I realized how much light was above the screen before. Other than that, I'm not sure. I have so much light colors in my room that I think it would take a lot more. The thing is though I'm happy with the quality (for now, I know how that can change) and I like having a light basement since we use the room for things other than movies.
I don't have a screen, I have a painted wall. The frame of the screen is moulding wrapped/stapled with black velvet. So the panels just "snap" in place held by the molding/frame. The panels are sintra plastic wrapped in stuff called pro star which is self adhesive and very black. They use it for telescopes.
With the panels in I have a 16:9 screen for tv, for movies that are 1:85 it's not a big difference, I have just a very tiny black bar at the top and bottom you really don't notice it.
post #226 of 243
I would've never known that was a painted wall instead of a screen lol good job!
post #227 of 243
Ha! I always wondered what screen was used, but never got around to asking.
post #228 of 243
Lovin' the new look with the Noe's, Carp. Should look even meaner when all the SI's get installed. wink.gifsmile.gif
post #229 of 243
Thanks Scott - yeah I'm at the mercy of when the 18" flat packs are done, can't wait.
post #230 of 243
Carp, are you getting 8 single flat packs or has Erich made DO flat packs for these yet? You will be on a different level when you get these running along with you Noesis. Very jealous smile.gif
post #231 of 243
I'm going with 8 separate boxes. I'm getting anxious, I want to get this project going!! Hopefully the flatpacks will be ready to go soon.
post #232 of 243
the links in your op are not working because there is a new method for importing images.
open the editor.
scroll down to the bottom and ensure that the "import images" box is checked.
place your cursor where you wish to insert and image.
select the image button to open the image dialog box.
plop the url into the bar.
the image is then grabbed by avs and stored on their servers.
for example, the image url:
http://i232.photobucket.com/albums/ee292/carlhungus2/018-2_zpscf89ed8b.jpg
will look something like this:
IMG ALT=""]http://www.avsforum.com/content/type/61/id/157697/width/350/height/700[/IMG
but will have brackets at the beginning and the end.
and will display like this:
your images are too nice to have them not showing up.
the new system for storing images locally is so that if the original photobucket image is deleted, the image will remain showing up on avs.
post #233 of 243
open the editor.
thanks a ton LTD, but I'm having trouble. When you say "open the editor" do you mean click on edit post at the bottom of post 1 of the thread? When I do that and scroll down I don't see anything that says "import images" with a box to check. Ha, so I guess I'm stuck on step one. redface.gif
post #234 of 243
if you don't have one of these, i'm not sure what to do.
also, i just skim read your entire thread. very nice transformation. hard to believe that pic with the fan and the track lighting was the same room.
post #235 of 243
ok, this is after clicking on the pencil icon to edit the post. No i don't have that import images to check mark, it only has the word cancel. Here is the message i get at the top.
"This is Rich Format content so you've been switched to the Rich Editor."
I'll pm a moderator and see if i can get it figured out thanks for the help and compliments LTD!
post #236 of 243
This was already one of my favorite rooms to look at and every time I stop in here you have some massive upgrades going on! Well Done Sir…WELL DONE!! I bet the Noesis sound as good as they look – just Badazz!! I’ve been following your progress on the 8 18inch SI subs in the DIY section as well. That also looks to be incredible and can’t wait to hear your thoughts once you get everything up and running. You should probably include the link to your DIY build in this thread and maybe even include the DIY link in your signature too.
post #237 of 243
Thanks Bunga! Yeah that's a good idea I should put a link in for the DIY thread. Ha, I just wish I could figure out how to post pictures in my first post on this thread. The upgrades have to chill for awhile after this, but I've been saying that for so long now!!
Lets see, for about 5-6 years I had Axiom speakers, SVS sub, and 65 rear projection tv (actually had that for 10 years). I buy a JTR Captivator and suddenly I'm in a constant state of making changes:
Since early 2011:
TV:
Epson 8350
DIY screen wall/masking panels (actually had that done by someone else)
Speakers:
Magnepan
Elemental Designs Cinema 12's
JTR Noesis
Subs:
Captivators
Submersives
DIY SI subs
Receiver:
Pioneer Elite vsx 53
Misc:
SMS-1
CV 5000 amp to drive SI subs
dual dedicated 20 amp lines
Sheesh, I bet I'm forgetting some things too. It really does become an obsession. I am still having fun with it, and nothing on credit card yet.... so I tell myself I'm ok. biggrin.gif
post #238 of 243
So how does your screen work with 2.35 content, it's zoomed in so much the black bars are above and below the screen? And when you want to switch back to 16:9 you dial the lens back and put up the masking? I just bought a 8350 myself and I'm trying to figure out a 2.35 solution or just stick with 16:9.
post #239 of 243
post #240 of 243
Haha, hey my wife has been driving illegally since 2007!
