Setting up my home theater and have purchased a LG 65, and it will be mounted on a wall inside my family room (15' x 25'). Got the Denon 2112 receiver, Klipsch RB61 & RC62 as my front and center speakers. Some ceiling mounted speakers are the rear.
Lastly I need to pick a subwoofer to go with it all. Need to keep it under $500. Was looking at the Klipsch 12. But also looking at the Velodyne EQMax10 and the Energy VSW10.
Can you recommend what's the best out of the three, or some other one under $500 (non-used). Will be using it for mostly tv/movies/games. And about 20% of the time for music. Don't need thunderous bass. Just look for good quality.
