I've read through the entire Grafik Eye sticky and I'm feeling a bit overwhelmed. I have a couple of questions, but first let me describe my setup:
My theater has (will have) 3 Zones:
- 2 wall mounted sconces in the rear
- 2 2' LED rope lights on the two steps leading up to the rear seating
- 3 can lights in front of the screen
I'm looking to create 3 scenes (I think):
1 - Clean up - All lights on immediately
2 - Access/Intermission - Stair lights and rear sconces fade to 25%
3 - Off/Watching a Movie - All lights fade to off
*I'm not sure if #3 counts as a scene or not.
I've already wired the room as follows
chained the two scones together and run a wire to the switch
chained the two LED rope lights together and run a wire to the switch
chained the three cans together and run a wire to the switch
I'm planning to control the lighting scenes via my HTPC and/or Logitech Harmony Remote
My questions:
Which Grafik Eye do you recommend? I'm looking to buy something used and don't want to spend a million dollars. I'm hoping no more than $400.
I was planing to run a single feed directly from the breaker to the Grafik Eye to power all 7 lights. Based on load this should be okay, but I was a bit confused if the Grafik Eye wanted a separate feed for each zone.
Is there some kind of add on I need to purchase in order to have my remote/HTPC control the Grafik Eye's IR? I already have an IR transmitter for the HTPC, but will the Grafik Eye need something extra?
My questions:
