Has anyone taken an active roll in designing their HVAC system? Or do most people just give general requirements to HVAC contractor and hope for the best? If you gave requirements, how did you test that they were met?
For walls I see people get pretty specific on how the walls are built to achieve low noise floor in room. I am looking for similar level of detail for HVAC in my room, or how to get there.
Some general questions:
- Is there a particular model or line of AHU that are noted for their quietness?
- With variable speed fans, can you set them to run low rpm for lower noise?
- Is it better to run the theater HVAC in a soffit inside of the isolation envelope (around the room), or external and drop the vents into the room?
- Is dual zone better than dedicated unit?
- Are dead vents quieter than normal forced air?
- For fresh air, are ERV units recommended or are they noisy? Are the make up air intakes enough?
- Recommendations are to oversize ducts, but how do I tell what size they should start at?
- How do people here maintain the recommended humidity ranges?
- Has anyone actually bought a system capable of the -30F ambient operating temperature that's been recommended here?
- Why is flex duct recommended over conventional square metal ducts with duct liner?
- Is it better to make 90 degree turns with a plenum, or just bend the flex duct? Wouldn't bending the flexduct cause turbulence which adds to the noise?
