I'm planning to add 3 can lights in front of my screen. But I have a few questions:
Also, I've already dry walled the room but decided to add these after the fact. Since I've spent so much time (and money) sound proofing everything, I'm hesitant to just cut holes in the dry wall and pop these in. Does anyone have any ideas? Before it is suggested, I do not want to use track lighting, I'm going to make Cans work, but I'm just not sure how yet.
- What size cans are most people using in front of their screens?
- Is one brand that is better than another?
- What type of lamp and what wattage should I use?
- Should I direct the lamp at the screen, or should I point it straight down?
They didn't have the pack when I was there.
