AVS › AVS Forum › Video Components › Home Theater Computers › hdmi not detected: gigabyte R455 - Marantz SR5006 - Samsung TV
post #1 of 8
Hi
I'm trying to get my HTPC updated to HDMI.
System specs
Shuttle SG31G2 windows 7
Gigabyte GV-R455D3 video card with HDMI (and VGA)
VGA connected to LCD monitor
HDMI connected via Marantz SR5006 to Samsung LCD TV
When the PC is connected directly to TV, HDMI is recognized and works fine (audio and video)
When PC is connected through AVR to TV (and any input other than the one on which the PC is connected) the PC claims to have an HDMI attached device (of course I don't see or hear it since the AVR has selected a different input)
When PC is connected through AVR with the appropriate HDMI interface selcted to connect input to TV then the PC says there is no device connected to HDMI and I get no video or sound. (i.e. I switch AVR to select input to which PC HDMI cable is connected)
This according to ATI Catalyst control center.
I'm running latest drivers (8.951.0.0)
When I try moninfo it tells me that the monitor info is the same when selecting the proper input or not on the AVR.
There are some differences in the moninfo report when connecting the PC directly to the TV but mostly in the audio section.
So my question is - how do I figure out what is wrong ?
Why is the device attached to the HDMI port not seen by the PC when the AVR has selected the PC as input ?
Why does moninfo see it but not the catalyst driver and hence windows 7 ?
Any help appreciated ...
Chuck
post #2 of 8
Do you have another card that you can test?
Are you playing Blu-Ray files?
HD Audio?
If so, upgrade your card to the HD5000 or HD6000 series. These will bitstream HD audio to your AVR, the HD4550 will not.
Two birds with one stone!
post #3 of 8
another observation is that on rebooting the PC that the boot messages come out on both the VGA attached display and the hdmi through AVR to TV up until the windows screen then the HDMI monitor goes blank
I'm guessing that this is the point at which some more sophisticated ATI driver software takes over and kills the HDMI connection for some unknown reason.
post #4 of 8
unfortunately no other PCI-E video cards and nothing with HDMI
Not using BlU-Ray on PC - I have a stand-alone Bluray player so no need.
Just trying to use mediacenter with my tuner card (but need HDMI input for my AVR)
post #5 of 8
There's your problem: dual displays!
Do you have the VGA connected while trying to use the HDMI connection?
Disconnect the VGA and then boot the PC with just the HDMI connection.
post #6 of 8
I disconnected the VGA display and only have the HDMI AVR TV connected and I get the same thing
TV display shows boot messages right up to the windows screen then the TV display goes blank and reports NO Signal
Can't say what the PC thinks since I dson't have other display connected but I bet it thinks no displays are connected ...
post #7 of 8
With the VGA & HDMI connected, try 'Detect Displays' in CCC.
You may want to look into an EDID override; search for that thread in this forum. It has some good info.
I still think your best bet is to try a different video card.
The HD5450 is on sale for $16 AR.
It will help rule out your AVR as the problem.
post #8 of 8
The HDMI interface works when I switch the AVR away from the PC input and when I plug it into the TV directly all automatically - no need to detect displays.
I did try detect display from CCC but it did not find the HDMI connected display when it was connected through the AVR.
However moninfo did read that there was the AVR connected so I don't understand why catalyst doesn't see it.
I guess I have to spend money to narrow the options
5450's aren't that cheap if you want to pick it up locally rather than wait for mail order but lets see what happens with a new card
Chuck
