When using this analog conversion, all my video is washed out looking because the black levels are not being converted correctly. The IRE is off. The receiver is scaling the black level as a 0 IRE when analog video uses 7.5 IRE as the black level. So when the receiver sees a 7.5 IRE Black level, it's 7.5 IRE over the receiver's reference black level, and therefore produces a brighter black or grey which washes out the picture.
I've delt with this years ago when DVD Recorders came out and Toshiba kept using a 0 IRE reference level for Black which was incorrect for the US NTSC format, but correct for the "Japanese" NTSC format.
The black level problems have since been straightened out for years and now I have this problem in a new product.
Yamaha is already looking at it and has escalated it to higher tech support/engineering. I would like to know a bit sooner since I'm within a 14 day return window plus I would like to confirm with actual owners if they have this black level problem when converting analog composite video to HDMI.
Thanks for the help in figuring out if this is a true hardware defect or a design defect. It will help with my case with Yamaha.
Thanks for the help.
