Decided to do some testing of in room response using some test tones today and the results were pretty poor.
I'm using an LFM-1 Plus and can't seem to get a good response no matter where I've placed it in the room, doing the "sub crawl" didn't translate into great results either. I've tried 6 possible spots and still the same bass response all around just about.
Basically in the 65-70 range it's about 5 db down with a peak near the 60-65 hz range, under that until about 39hz I drop a good 20db and below that I'm not hearing a thing. The woofer is moving down to the 20hz test tones (Subwoofer set on maximum output) but I don't hear a single thing even with the receiver playing at -5 db (What I usually listen to movies/music at). Keep in mind this was done in the main listening position using an iPhone SPL meter
Will adding a second LFM-1 Plus solve these issues? The room is 19L x 14W x 8H, one odd doorway that opens into a hallway, room is around 3500 cu. ft I'd say.
Knowing that the subwoofer can do 25hz +/- 3db and not being able to even hear anything under 40hz is driving me insane to say the least.
I could MAYBE get away with one large bass trap, would that have any decent effect?
Thanks in advance for any advice
