Well, I thought I'd quit at the "two hole" data set above, but I wanted to see if I could do better. I added another row of holes closer to throat, and ended up with this iteration. The "5/6/3/2" hole pattern seems to provide the best balance of low end and high end response (kind of looks like that sailboat I used to see on those old "light-brite" commercials from the 70's and 80's... or maybe just an origami paper hat).
I've shown comparison to the original "two rows" data (shown in my lat post) as well as another pattern in the hole plate. Notice the extended low end response of the BMS 4550 from 1-1.5k as well as the smother top end from 3-6k. And, compared to "two holes", I'm only taking <1db hit on the alphas from 350-500hz.
I'll now have to make a dedicated plate with only this pattern so that I can confirm its superiority and move forward with further testing. We'll see what happens next!
John
Edit: adding some construction data: hole plate 3/16" thick; distance to first row (the "5" of "5/6/3/2") is 7.3 cm compass radius from outside center point at CD mounting plate attachment
Edited by johnbomb - 9/25/12 at 7:07pm
John
