In some respects yes, in others no. I wouldn't replace a solidly-built Bryston amp in my room with a cheesy-looking Crown XLS DriveCore or Peavey IPR, unless the amp was hidden out of view.
Probably indifferent, as there probably won't be any material differences.
HOWEVER, one thing to consider is that with most of these new budget class D amps, there's no headroom beyond the power spec. (The IPR-series designer pointed that out somewhere.) So, to be conservative you should probably look to a class D unit with at least 3dB more specified "continuous" power than your current Bryston. (Also, when comparing IPR to iNuke, consider that the actual equivalents are IPR1600 to NU3000, and IPR3000 to NU6000.)
Speaking to the IPR 3000, as that's the only budget class D amp I've had in my system, too loud to have it in the listening room. Even after I swapped the fan for a much quieter Noctua unit, it was audible on startup and during quiet passages.
I do have another Class D pro amp (Electrovoice CPS 8.5, 8 channels of 500W/4Ω each) that's much quieter. However, it's also made in Germany, and costs 3k USD plus or minus a bit.
Maybe.
Yes. The 1000 has a higher noise floor. Something about the main chip handling a codec on the 1000 that the higher models use a separate chip to do. Whether that matters in a given system...no idea.
Originally Posted by commsysman
Q1) YES! Those are public address system amplifiers; not suitable for home stereo; terrible sound quality.
Q2) Unless your ears were severely damaged in the artillery corps, you will find the decrease in audio quality completely unacceptable! On a scale of 1 to 10, you will be going from an 8 to a 2.
Ill-informed at best, willfully misleading at worse. (Do you sell so-called high end audio gear, perchance?)
Have you actually heard one of these amps, or are you just making idiot assumptions?
Even people who imagine differences in amps have good things to say about them. Here's a subjective review from someone a little more thoughtful and open-minded.
Originally Posted by chasw98
***I used the [IPR 1600] for a while in my bedroom system that uses a pair of Dayton 3 way floorstanding speakers with dual 8 inch woofers, 5 1/2" mid, and Seas H1212 tweeters. Over the years I have used many different amps in the bedroom (usually cast offs from the main system) such as Onkyo receivers, Bryston 3B-ST, Hafler DH-220 modified, and currently a Harmon Kardon AV receiver. I heard a much cleaner upper mid range/high range than I have heard with any other of the mentioned units. I find it very hard to admit that the Peavey IPR-1600 sounded really good as a full range amplifier because my own built in prejudices formed over many years of using pro gear and home audio gear still tell me quite loudly that "PEAVEY IS NOT A HIGH FIDELITY AMPLIFIER". But my ears told me that I could hear more detail that was cleaner and more open than the other amplifiers. It has been quite hard to get over built in prejudices vs. what I heard.
