AVS › AVS Forum › Audio › Speakers › klipsch promedia 2.1 Wall Mount
post #1 of 5
Anyone Know of any wall mount or floor stand that works with these the WB1 from klipsch i cannot not find anywhere. thanks
post #2 of 5
I am looking for the same thing... They do not have the normal mount hole on the back. Is there a way to mount these guys to the wall?
post #3 of 5
I'm not familiar with all of the various iterations of these speakers, but if all else fails you could always use a "floating" shelf:
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=floating+shelf#/ref=sr_kk_1?rh=i%3Aaps%2Ck%3Afloating+shelf&keywords=floating+shelf&ie=UTF8
Shop around--some of these things are quite unobtrusive, and it shouldn't take much weight-carrying capacity to hold up one of these speakers (they're only like, what, 2 lbs?).
post #4 of 5
Yes. The standard wall mounts you find at Amazon or BB or Monoprice will work - I just wall mounted a set I got from Salvation Army.
Unscrew the table stand to free the one screw hole in the satellites. Using the two hole mounting bracket, screw the speaker in with the provided screw (the original one will be too short). The other hole in the bracket will be free, but if you screw in the first hole with 2-3 washers to act as spacers, it should fit flat and flush against the bottom of the speaker. Mount to the wall and enjoy! Careful though, my 12 gauge wire didn't fit and I ended up splurging $7 on some 18 gauge to tuck into the clips.
Good luck!
post #5 of 5
  Back to Forum: Speakers
