http://www.tvfool.com/?option=com_wr...7fcfc292bdb436
My house is out in the country. Good sight lines and close to towers but the angle is fairly wide at about 160 degrees from one tower to the other. Thinking about getting the Monoprice outdoor antenna.
4 locations that I need to distribute the signal from the antenna. They won't be extremely long runs. 3 of them would be under 40 ft. One would be about 60 or so.
Should I be looking at a distribution amp?
http://www.channelmasterstore.com/An..._p/cm-3414.htm
