post #1 of 1
I'm having an issue with my 609 & McAfee Firewall when I stream from my Win 7 pro Music folder it will loose connection after 5 minute - If I Disable my Firewall (turn off) It will play for as long as I have it disabled.
What Port or ports should I have open in order not to loose the connection?
Firewall Version 12.0
Build 12.0.345
I found My Issue - It is with my local firewall setting - To test - disable the firewall on any PC you are connecting to - if the connection does not drop then look into your McAfee firewall settings.
Double-click the M icon.
Click Web and Email Protection drawer.
Click Firewall.
Within the Firewall menu click the Ports and System Services drawer.
When That Opens --Click the Bar that says- Universal plug and play ports -Then Click edit - the go to the drop down window and change it to "all PC"S"
Click Save
Your Onkyo will no longer drop it's connection.
