Has anyone attempted moding the internal selectable high pass filters in either of these amps? It seems an awful waste to buy this amp and then have to buy an additional filtering device for $50-$100+ more when there is already a HP filter inside.
I found a website with a blog post discussing the possiblity of modding this and he highlighted an area in the schematic that appears to be a passive 2 stage RC HP filter. I spent some time studying the schematic myself and have come to the same conclusion based on signal routing.
For the 50Hz filter it uses 2x 150 nF caps and 2x 20k resistors for a cutoff of fc=1/(2*pi*sqrt(R*R*C*C)) = 53.05 Hz
For the 30 Hz filter it adds in a 220 nF cap in parallel to the first 150 nF cap for a combined capacitance of 370 nF on the first stage. This gives an fc=33.7 Hz
I attached a sample from the schematic to illustrate. This is for channel 1; channel 2 has identical filtering. The input signal +/- is on pins 2&3 on the left labeled X10 respectively.
I plan on building a custom sub soon and will likely attempt this in a month or two from now unless someone has had a bad experience doing this. I do not own this amplifier yet.
