AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Which is better at matrixing: DSX or PLIIz Height?
post #1 of 7
So i'm curious at which format is better matrixing the height ambiance channel from a standard 7.1 or below source?
Audyssey DSX Height or Dolby's PLIIz Height?
post #2 of 7
DSX doesn't matrix ambience, it uses the contents exclusivelyfrom the front L&R channels to generate proscenium reflections based on concert hall acoustics. By comparison, PLIIz extracts decorrelated (out of phase) ambient information from the surround channels to feed the height speakers.
post #3 of 7
I see, I wasn't aware but I get the idea of what you are saying.
So in your opinion which would be the more accurate and better method?
post #4 of 7
The list is incomplete...
You should add DTS Neo X...
Just my $0.02...
post #5 of 7
My 608 doesn't have that
post #6 of 7
You should have included Yamaha's Height channels as they have much more experience with this than either of the 2 you mentioned. They have been doing height channels for over 12 years. My old RX-V2095 had these speaker outputs although I never used them. The new models also have them and why they don't offer DSX or DPL IIz (just DPL IIx).
Once again I don't use them but for years Yamaha has always got the thumbs up for great height imaging with their height channels.
post #7 of 7
More accurate to what? If I want to feel like I'm listening in a larger room, then I would use DSX. If I want surround ambience to come from above the front soundstage, then I would use PLIIz. I doubt that film makers and their sound mixers intended for either of those effects, so I'm not sure whether I'd consider either one "accurate".
