Originally Posted by Mfusick
Instructions
1. Remove all Hard Drives currently connected to you system with the exception of the targeted SSD or traditional SATA Drive that will be used for either your WHS 2011 Operating System .
NOTE - Remember to insure all previous Data you want saved from the targeted drive is removed before installation or it will be permanently lost.
2. Format an NTFS USB Flash Drive, and create a file on it using notepad in the root called cfg.ini. (Insure there is nothing else on the USB)
3. Open the cfg.ini in notepad or any other text editor
4. Cut and Paste the following into the cfg.ini file below
[WinPE]
ConfigDisk=1
CheckReqs=0
WindowsPartitionSize=MAX
5. Close the file and save it on the USB Flash Drive.
6. Insert the USB Flash Drive with the cfg.ini file into the targeted WHS 2011 Server's empty USB Slot.
7. Power up your Server and insure that either your Windows Home Server 2011 install DVD has been inserted into your Servers ROM.
8. Once your Server has booted off the install DVD the Installer will read the CFG.ini file and begin the automated install process. There should be NO User Input required during this time.
9. When your Server Installer has finished its first part of the Install and goes to reboot for the 1st time REMOVE the USB Flash Drive and the Install DVD from your Server BEFORE your server boots back up ( As shown below). This will allow the Server upon rebooting to find your hard drive and continue the installation from there without further interruption.
10. No Further action on your part will be required and the rest of the install will finish automatically, again without any user intervention.
11. Once the installation has completed please plug in any other drives and continue with completing your server build.
Instructions
[WinPE]
ConfigDisk=1
CheckReqs=0
Guys I need help. I am having issue installing with this method. I am not sure what I am doing wrong.
I took a USB3.0 8GB stick- formatted it NTFS- then I named a wordpad document cfg.ini and saved it to the USB stick. IT is the only file on the USB stick.
I opened it up- copied and pasted:
[WinPE]
ConfigDisk=1
CheckReqs=0
Then saved it again to the USB stick. I verified it was there, then inserted it into my Server motherboard.
The only drive I have hooked up is a 60GB SSD drive, and also a SATA DVD drive to install the DVD install disc from.
The instructions say no user input required. But when I boot up it goes to the screen asking me for new or existing install.
If I choose NEW then it gives me an error message. I assume the error is that the drive is too small.
HELP ???
Idea?s
