AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sony HX850 Owner's Thread (46HX850, 55HX850)
post #1 of 1970
Use this thread to discuss the new 2012 HX850.
Specs:
Edge-lit LED TV with local dimming
X-Reality PRO Engine with 3D Super Resolution
Motionflow XR 960 (240hz refresh rate)
Active 3D compatible
Thin bezel with Monolithic design and Gorilla Glass
Built-in Wi-Fi
Sony Entertainment Network and apps access (Hulu, Amazon prime, Netflix, twitter, facebook, youtube etc)
Skype-ready (Camera needed, purchase @ Sony store)
Official Sony link:
http://store.sony.com/webapp/wcs/sto...HX850#overview
Sony Video on the HX850:
http://www.youtube.com/watch?v=CAOF1IL9ej4
Amazon:
http://www.amazon.com/Sony-BRAVIA-KD...5494419&sr=8-2
Reviews:
http://www.flatpanelshd.com/news.php?subaction=showfull&id=1335250671
http://www.t3.com/reviews/sony-kdl-55hx853-review
Praise from current.com.au (brief overview of the 850)
http://www.current.com.au/2012/04/26...AYMUGARL.html?
post #2 of 1970
Anyone know why flatpanelshd mentions google-tv ready in their description of the set? Was this announced at all at CES or something? because it looks like they were mistaken (hopefully they are not mistake because i really want gtv)
post #3 of 1970
Originally Posted by Gregck View Post
I am not experienced enough to comment on that but the off-angle viewing is definitely better, i cannot notice anything that resembles a "halo". As far as DSE, no idea what that is. I'd be happy to look if described what i'd be looking for.
Thanks, DSE (Dirty Screen Effect) are blotches/marks on the screen that are easily noticeable when the TV does a panning shot vertically or horizontally and more so when the background is a solid color, such as a blue sky or a soccer pitch.
post #4 of 1970
Ah ok. I have noticed that on an all-white background. (using my computer) It seems like the whole screen is a little dirty. However I have barely adjusted anything, i am still debating on what calibration disk to get.
post #5 of 1970
Thanks Greg.
post #6 of 1970
Here are the links / info on the slick Monolithic stands that are available as an added option.
Here is how it looks mounted with the TV:
http://www.flatpanelshd.com/news.php...&id=1326241462
$150 for the 46"
http://store.sony.com/webapp/wcs/sto...#compatability
$180 for the 55"
http://store.sony.com/webapp/wcs/sto...52921666424876
post #7 of 1970
sucks it did not come with that stand but at least it available.
post #8 of 1970
Picking this up soon!
post #9 of 1970
So has anyone here been able to see an 850 in person and compare it to the picture quality on a 750 to ensure the blacks and contrast are better?
Still on the fence if I should wait to get the Panasonic WT50 series instead of this.
With the news about Sony and their business and moving away from TVs....
post #10 of 1970
I have had the 46HX850 for almost a week now and i have seen the 750 in person as well. Without a doubt, the hx850 is the clear winner. With a few adjustments, i can get totally black with no flash-lighting, just like my hx820.
One thing i do not like is a new feature they added that turns the backlights off completely to go 100% black. I'm not sure if i can turn this off but it's annoying.
post #11 of 1970
What adjustments did you have to make? Was it for example to turn the backlight down, and in that case to what level?
Also, how does the HX850 compare to the HX820? Any major differences, or are they similar?
post #12 of 1970
Mostly turning backlighting down. I have mine set at 5 for game mode and 4 for cinema.
The two sets are very similar, HX850 has a small/better bezel, a faster xreality chip and a better panel. Picture quality is above the 820 but black levels are the same for the most part. the remote for the 850 is really bad and it has no illuminated sony logo. But other than those 2 things it's an overall (and much more expensive) better tv.
post #13 of 1970
Really interested in this set.
Any chance of some pictures of owner set ups?
I know you can see pictures online but its good to see real pictures so to speak.
Aaron
post #14 of 1970
Thanks. Could you please elaborate a bit regarding what you think makes the picture on the HX850 better? Are you for example referring to viewing angles, less motion blur, or something else?
Also, did you get any flashlighting before turning the backlight down? What if you watch letterboxed movies in a completely dark room for example?
post #15 of 1970
According to multiple sites, the 4x super resolution panel used in the hx850 is the same used in the hx929. everything seems at least a little bit better, motion blur is definitely a lot better on the 850.
Yes, there is flashlighting on this set. You will NEED to turn down the backlight in order to get rid of the flashlighting. You will notice flashlighting on letterboxed videos for sure, you will need to adjust settings and eventually you will be able to have a 100% black experience (letterboxed vids too)
post #16 of 1970
Having seen a few of these in the store the picture quality in cleary better than the hx750. I do think the 820 is a much nicer looking set though. Have no idea which one has a better picture though. I would be intrested to know if it is clearly beter. I like the silver lining, but the stand, lack of logo, and remote are terrible.
post #17 of 1970
Yes, that is the same experience I have from the two HX820 sets I've seen. At least on those two sets there was a little flashlighting in the bottom corners when watching letterboxed movies in a dark room (not very pronounced however, sometimes depending on content you really have to look for it to see it). Also the flashlighting is not visible when watching normal 16:9 content (even in a dark room), and not when watching letterboxed movies when the room is lit (even if the lights are quite low). I should also add that when watching off angle more than ~ 20-30 degrees, blacks gradually turn grey/blueish. But that is common for all LCD TVs due to poor viewing angles for the LCD technology.
Also turning down the backlight helps to reduce the flashlighting a bit, but not completely. Unfortunately, turning down the backlight also results in black crush (i.e. loss of contrast in dark areas, where dark grey also looks just black). So ideally I like to keep the backlight at 7 (i.e. default setting), since then there is no black crush, and the image looks fine for most content I watch. But in Cinema mode when watching movies I have set it to 5.
Finally, I might sound a bit negative above, but that's probably because I am somewhat of a perfectionist always looking for things to improve. So just to clarify, in general I have to say I am very pleased with the picture quality of the HX820. Compared to other TV sets on the market it is definitely one of the best out there, and other sets have similar flaws too (most have many more flaws!). Many people just don't know what flaws to look for and how/when to spot them. Hence they often do not notice them (poor bastards, they don't know what they are missing! ). Also, I must add that the HX820 set itself really looks amazing!
But it will be nice when OLED TVs start to arrive at decent prices, and we can all forget about flashlighting, backlight bleedning, clouding, black crush, low contrast, bad viewing angles etc that are all common for LCD sets.
post #18 of 1970
Sorry that is not quite right, brightness controls blacks and controls the amount of detail you see. Backlight is purely the luminance of the display or the amount of light the display outputs. Brightness should be set correctly with a proper test pattern so you get no black crush or over exposure of dark areas.
Aaron
post #19 of 1970
The two sets are very similar, But other than those 2 things it's an overall (and much more expensive) better tv.
There can be no comparison pricewise as the hx823 on release was more expensive?? Sony outlets are selling off hx823 sets to concentrate on the hx853. As they possibly will with the hx853 in 7-8 mths time. I say possibly because they have cut back 50% on tv production,last year i would have said definately! Also had a look at this baby today in my local A/V superstore,picture-wise looks similar to the 820 with minor flashlighting in corners,but it was barely noticiable,nice blacks on cinema mode with lovely colourfull picture it would be hard to point out picture differences within 20 mins.
It looks smaller than the 820 with a slightly slimmer bezel,but the silver coloured strip adds class. Sound is v.good for a edge-led tv,again with the noise i cudnt really tell any comparison,but it sounded "bassy". Like all the monolithic sony sets,it looks v. classy without overdoing it,again the silver strip giving the extra look to the overall tv. It was on a stand almost identical to the hx800 stand,but sturdy enough,with the monolithic stand costing extra?? as i didn't see 1 there. Well if i had 1700stg & was in the market i would take a real close look at it,it had Underworld 3 playing & the dark moody scenes,looked detailed & clear,i saw the same movie on the hx820 & it has very similar approach to darks & blacks with great shadow detail. V. nice tv...keep it up Sony
post #20 of 1970
Aaron
If you turn down the backlight it will affect the brightness of the colors as well. I.e. light grey becomes dark grey, and dark grey becomes black and so on. I.e. if turned down too low you'll get black crush.
Just turn it down to 0 and watch the black crush. It will be very obvious to you.
post #21 of 1970
That is why you adjust the brightness accordingly, low backlight doesnt instantly mean black crush, you set the backlight to the light output that suits your environment/preference, then use test patterns to set brightness, contrast, colour and sharpness etc.
Aaron
post #22 of 1970
Aaron
If you compensate a low backlight setting by increasing the brightness setting you'll get white crush instead, which is no better.
You make it sound like it's a no-brainer to turn down the backlight to zero. If that would be the case and there would be no negative side effects, why doesn't the manufacturer have that as the default setting?
post #23 of 1970
I did not say that at all or made no suggestion of backlight at minimum as being best, what i said was -
"you set the backlight to the light output that suits your environment/preference"
If you are going to quote me, actually quote me.
Also brightness controls black intensity not white.
I think you will find manufacturers have bright default settings because, bright and punchy sell to the majority that don't know any better.
I actually came here for owner pictures, not for a disagreement.
post #24 of 1970
post #25 of 1970
Thank you very much, what a looker
Aaron
PS was the hard2beat deliberate?
Thanks again.
post #26 of 1970
Aaron
Thanks again.
Let`s play some rounds of MW3, and we shall see who is hard2beat.
post #27 of 1970
Sorry i am a Gears Of War 3 man.
post #28 of 1970
Can anyone tell me how the 850 stands up against the 929 3D wise?
post #29 of 1970
The panels are the same except the 929 has local dimming. 3D is similar to the 820 but better. Both the 850 and 929 suffer from off-angle 3d viewing. Unwatchable if you tilt your head at all. Maybe the new glasses fix this? im using the tdg-br250s and 3d isn't really enjoyable on any sony tv.
post #30 of 1970
I appreciate your opinion of 3D on Sony TV's.
The 3D on the GT50 is outstanding, hard to pass out.
Still considering on going with a larger size GT50 since I do a variety of viewing styles in general.
