Originally Posted by HaRd2BeAr
Use what looks best to your eyes. I personally found using Warm 2 plus turning green gain down in the white balance git rid of the dirty affect. Neutral on these set's isn't neutral as in no bias either way, i know this may sound strange to some but it is Sony's interpretation of neutral and is heavily blue tinted.
You could also tweak red gain but by eye is not the easiest or most accurate way.
Before anyone says why not just use neutral then instead of tweaking red out of warm. Well if you used Neutral, you would need to take huge amounts of blue push out and it would be very difficult to get colors natural.
The thing is, blue color errors are harder to detect than red or green. It's just how our eyes perceive the image and colors.
Aaron
Aaron
I agree with HaRd2BeAr that using Nuetral is not a very good choice because the white is not really white but blue tinted white. Its been that way always at least with sony tvs. I have an 2001 sony XBR CRT tv in my dinning room and even then neutral was blue tinted. Idon´t tweak the white balance because honestly i don't know how to do it without the proper tools of a calibrator. Is my understanding that without a colorimeter and the pertinent software to measure the color temp you cannot calibrate the white balance acurately, but if HaRd2BeAr knows a way to do it without it and get good results, please explaint to us. I have always wanted to know if there is a way to do it withou the proper tools?. I won't use clear white at al,l because options like that one or black corrector what they do is increase the black or white but crushing shadow detail in the process. stay away from those two!
rajivr, in the end like HaRd2BeAr said, used what looks best to your eyes just let tell you that that preferences change over time. From 1999 to 2003 I used neutral becuase i like it in CRT tvs. from 2003 to 2011 always used warm 1 because I cannot longer stand neutral and I percieved warm 2 to have to much red and soft whites. Maybe the problem were my tvs (sony S3000 and later sony Z5100) because i cannot do a professional calibration of the white balance even if I wanted to (in my country there are no professionals in this area unlike the US). Now in 2012 I'm really enjoying the Warm 2 setting in Cinema 1, the colos are full and well balance and i Know the white is not pure white but i like the way it is, and I think is because like the Cnet and FlatpanelsHD reviews said, the color the HX850 display in the cinema preset is very acurate, so it is very close to the specification of a proper profesional calibration. Just compare the same images in warm 1 and later in warm 2 and IMO the latter came out on top.
