Windows 7
You can find and download the official Windows 7 ISO images directly from the MS Store, using these links. These ISO images are perfectly legal since they do not include any type of serial key.
The Windows 7 USB Tool from and use it to create a bootable USB drive ( a 3GB or more USB thumb drive is required) from which you can install Windows 7.
- I know I can do this with HOME and I currently have both the USB program and ISO- and I have installed this before.
What I don't have is the PRO version. I do own two versions of PRO. I have original, and an OEM version with SP1.
Anyone know how I can install PRO from a USB?
I would like to make a USB3.0 boot stick so I can load pro onto many PC's and install faster than a typical DVD allows.
Of coarse I need different key codes for each machine- but I have that.
Does something like this below exist for PRO version of WIndows 64bit ?
------------------------------------------------------ - Windows 7 Home Premium 32bit : download
- Windows 7 Home Premium 64bit : download
- Windows 7 USB Tool : (download)
