AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Vacuum Cleaner on Projector?
post #1 of 2
Hi,
Can I use a vacuum cleaner to clean my projector?
post #2 of 2
If you have to clean a filter, need to be very carefull...I had cleaned mine several times with the vacuum cleaner, but the last time it sucked it in and broke it. So I had to get a new one.....for the PJ casing itself, I used a very lightly damped cloth with much care not to touch sensitive parts.....
The JVC manual states not to use cleaning liquids on the lens so I have used a very delicate brush to brush off the dust......
check your user guide to check what they recomendt..
