AVS › AVS Forum › HDTV › HDTV Technical › Sharp LC-45GX6U - What to do?
post #1 of 3
Greetings Colleagues:
I have thoroughly enjoyed my Sharp LC-45GX6U for over nine years now, however, I am experiencing a problem, and would like your advice.
When I use the remote to turn on the TV, after about a 30 second pause, the Box shuts off, and the grey/white screen appears. If I repeat the process, maybe five times, the green light on the display comes on, followed by a click and picture. A picture, I might add every bit as good as the day of delivery. For the moment, I leave the box' on, and turn off the feed (Comcast cable box).
Reading through the forums, I am not alone. Others, more technically oriented than I, have replaced a power board' with great success. Unfortunately, I do not know what a power board' looks like, much less how to replace one. Still, I hate to part with an old friend, if a reasonable (<$300) repair can be made.
Is there somewhere I can take/ship the Box for diagnosis and repair? I live in Fort Lauderdale, FL, an easy drive to Miami, or West Palm Beach.
Perhaps, nine years is the lifetime of the unit, and I should purchase a new HDTV?
Any advise would be appreciated.
All good things,
George
post #2 of 3
I wouldn't spend the money to get a set that old repaired.
Why? Because you can get a new 1080p 46" LCD for $400. ( http://www.sears.com/shc/s/p_10153_1...8&blockType=G8 )
Even the least expensive current 46" HDTV will look better than your existing set did when it was new. Display technology has advanced that much.
Having said that, spending more if you can afford it will get even better picture quality.
post #3 of 3
Thanks, Ken.
Appreciate the reply.
Thought I would put the ‘old’ set in the bedroom, and buy a new one.
Again, thanks for the input.
All good things,
George
  Back to Forum: HDTV Technical
