AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › BERKLINE 12013 - anyone have them? is it the same as another seat?
post #1 of 8
I cant find anything about these seats, which suggests why they are cheap. Are they under another code? or maker?
post #2 of 8
Metric,
What exactly are you looking for? You can still find some of the Berkline 12003s, and the Lane 103 is the same chair.
post #3 of 8
Im under a tight budget. Ive found these seats Berkline 12013 Regal - Row of 3 with free power recline and free shipping for $1197
post #4 of 8
Sorry about that I misread your post, and thought you were asking about 12003. My apologies.
Make sure you get some kind of warranty since the Berkline is out of business.
post #5 of 8
Yeah, they definately dont have any warranty... im pulling my hair out on what to do. I want power but i have a tight budget... do i buy closeout berklines and risk it, or try to find somewhere with a warranty.
I cant find anything about these seats either.
I did find 13174 the same config for $1350 with a warranty but im not sure those chairs will fit me, 6' 2"
post #6 of 8
the 13174 may work, but you may also want to check the Berkline 12000 or 12011, which have 1.5" higher backs then.
post #7 of 8
I looked at your link... 12000 looks nice, if only it were black
post #8 of 8
I just ordered the 13174 row of 3 power recliners from your site. It wasnt worth the 50 bucks to shop elsewhere given your reputation here.
Im not too far from you so maybe Ill get them this week....
