Please Post your settings here. I'll start with a few that are posted on the web. All credit goes to D-Nice and C-NET for the following-
CNET Review Settings:
--Picture menu
Picture mode: Custom
Contrast: +82
Brightness: +60
Color: +46
Tint: 0
Sharpness: 0
Color temp: Warm 2
Color mgmt: Off [grayed out]
C.A.T.S.: Off
Video NR: Off
-- Pro settings submenu
Color space: Normal
W/B high R: +10
W/B high G: 0
W/B high B: +3
W/B low R: +4
W/B low G: 0
W/B low B: -2
Black extension: 0
Gamma adjustment: 2.6
Panel brightness: Mid
Contour emphasis: Off
AGC: 0
-- Aspect adjustments submenu
Screen format: Full
HD size: Size 2
H size: [grayed out]
Zoom adjustments: [grayed out]
-- HDMI settings: [no change from default]
--Advanced picture submenu
3D Y/C filter: Off [grayed out]
Color matrix: HD [grayed out]
Block NR: Off [grayed out]
Mosquito NR: Off
Motion smoother: Off
Black level: Light
3:2 pulldown: On
24p Direct in: 60Hz
--Picture menu
Contrast: +82
Brightness: +60
Color: +46
Tint: 0
Sharpness: 0
Color temp: Warm 2
C.A.T.S.: Off
Video NR: Off
Color space: Normal
W/B high R: +10
W/B high G: 0
W/B high B: +3
W/B low R: +4
W/B low G: 0
W/B low B: -2
Black extension: 0
AGC: 0
Screen format: Full
HD size: Size 2
Mosquito NR: Off
Black level: Light
3:2 pulldown: On
24p Direct in: 60Hz
I was messing around with 3d settings yesterday, but couldn't settle on any particular settings. I am also having trouble finding good settings for standard mode (for daytime viewing). Cinema mode on default is what I've been using, but I'm starting to think I'd like a bit more "pop" in the daytime. The problem is, on standard mode, if you turn the contrast up too high, faces start looking washed out.
