AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung choices
Samsung choices
post #1 of 7
Hi all I was hoping I could get some advice on which display has better picture quality? I know the size difference is a consideration but I want the better picture. The choices are samsung LN52A650 or samsung UN46C6300. Thanks everyone for the help.
post #2 of 7
Pls... is anyone familiar with these displays
post #3 of 7
those are both discontinued models, are you buying a used TV?
post #4 of 7
No, my father was asked to swap tv's with a friend he has the 46" and was offered the 52"
post #5 of 7
I'd take the A650.
post #6 of 7
Just because of the size or because it has a better picture
post #7 of 7
both and also screen uniformity
