AVS › AVS Forum › Other Areas of Interest › Camcorders › Joining .MTS files without it glitching out
post #1 of 2
I'm trying to join multiple .MTS files without having to re-encode. I've used a few different tools including tsMuxeR. The result is the same for all of them. The video goes black at 1:06 and the image flickers on and off. Sometimes Windows Media Player crashes.
Is there anything I can do to fix this?
post #2 of 2
You should look at Aunsoft FinalMate.
The software allows you to take MTS files and append them together without encoding. The software allows you to convert to a different format also.
  Back to Forum: Camcorders
