How do you match a sub to your speakers?
I am considering buying a sub for my second system and am not sure what would be the best fit. My current speakers are the Dali Mentor 5.
It is powered by a NAD C372. (150 watts)
This is just a 2 channel set up so it would be a 2.1.
What do I look for?
Should the sub be the same wattage? Should it be double or more?
Sticking just to this page for now
http://www.psbspeakers.com/products/subwoofers
Which of these is best suited to compliment my Dali Mentor 5 speakers?
What do I look for?
So watts and size are of no importance?
