AVS › AVS Forum › Audio › 2 Channel Audio › Need some quick help here ... Peachtree Audio
post #1 of 3
I've been using my Luxman R-117 (160w/8ohms) ... with a newly acquired Firestone - Fubar IV Plus - 192 kHz Upsampling DAC/24 bit. My Mac Mini is the source via the USB port.
I was thinking about the Peachtree Audio Decco2 as a replacement (40w/6ohm). It has a built in Dac.
They will be powering ADS L300 Bookshelf speakers or Monitor BX2's with a powered sub.
Is this a poor decision? Should I just stay with my current setup? Thanks!!
post #2 of 3
What don't you like about your current system, and why do you think changing components (especially to lower power) will sound better?
--Ethan
post #3 of 3
--Ethan
I actually like my current system . And the lower power probably will be a problem once I get my JBL's going again. Thanks for your reply!!!
