1st off my Yamaha AX-497 is by no means a cheap receiver (it's actually a HI-FI AMP)
It maintains a THD of 0.019. Your best A/V/R recievers cant match that.
In my opinion AVRs are for the average consumer. So much money is spend on all the HDMI connections, the panels, 3D crap, multiple audio channels, blah blah blah. What im getting at is they dont spend there money on the "sound". As long as sounds comes out 99% of the general public are happy.
Even the most high end audio stores ive been to STILL run cd players and amps.
I even compared the xonar vs my on-board Realtek ALC888 chip-set and I can honestly say it's more accurate than the xonar.
The ST just sounds "tangy" a common misconception of quality.
I A/Bd three of my friends including myself using the Asus Xonar ST vs the simple cd player and all 3 came to the same conclusion.
The CD player sounds better.
Something that many in this site have a hard time accepting as fact. Thus it is better to avoid using the term "accuracy" unless you have the graphs etc to prove it. An accurate sound may sound worse or boring compared to a slightly altered one. For example the sound of the Xonar without using Asio to my ears is superior but I know without Asio it's most likely inaccurate with boosted midrange.
